| This is a discussion on A/C AUTO -- set it and forget it? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Mitch: Also remember that the car relies upon "recycled" cabin air to cool the traction battery (that's what that mysterious ... |
| | #11 |
| The Regenerator Join Date: Jul 2006 Location: Pensacola FL
Friends: 0 | Mitch: Also remember that the car relies upon "recycled" cabin air to cool the traction battery (that's what that mysterious vent by the right rear passenger's shoulder does). Though it may not be a huge issue in your climate, trying to "sweat it out" to save gas as you might do in a conventional car, can turn counter-productive should the TB get too hot. The ECU will act to protect it if it does, and the result will be an mpg hit. I'm with the set it and forget it group. Just use the temp settings to moderate it (and occasionally mode too), and you'll do fine.
__________________ ScanGauge-IIx for the TCH CAN View V3 (for when I care about maximizing Prius benefits). Valentine V1 (for when I don't care. . . ). Now in the TCH -- with Remote Display. Black 09 Camry Hybrid Cassis Pearl 07 Avalon XLS Black 04 Prius |
| | #12 |
| Junior Member Join Date: Aug 2009 Location: PEI Canada
My Car: 2010 Prius Model: II Package: Base (Canada) Thanks: 0
Friends: 0 | So let me see if I understand this...if I turn off the A/C when in "Auto" mode then the system will still still try to meet the target temperature....right? What happens when you are not in "Auto" mode and have the A/C turned off...does the system still try to meet the set temperure? The Owners manual entirely skips how the system operates when not in "Auto" mode. |
| | #13 | |
Friends: 10 | Quote:
Tom | |
| | #14 |
Friends: 23 | |
| | #15 | |
In an older conventional car there is a manual heat setting, non thermostatic, that regulates how much air passes through the heater core.....Does the Temp setting on the Prius also determine the amount of air passing the heater core ( or regulate the temp of the heater core itself? | |
| auto, forget |
| I'll never forget old what's his name | hyo silver | Fred's House of Pancakes | 16 | 09-30-2008 11:43 PM |
| Forget the Hybrid | Rancid13 | Prius and Hybrid News | 17 | 10-13-2006 05:32 PM |
| How Quickly They Forget! | Jeannie | Gen II Prius Main Forum | 7 | 05-31-2006 12:05 PM |
| Forget CNN. | Godiva | Prius and Hybrid News | 14 | 05-12-2006 01:15 PM |
| how quickly they forget | Bob Allen | Gen II Prius Main Forum | 3 | 02-04-2004 07:26 PM |
