| This is a discussion on Unstable at higher speeds within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Yes I meant 60 not 50 for those tires, a typo, sorry. Although I only have about 50K miles on ... |
| | #91 |
| Junior Member Join Date: Mar 2009 Location: San Diego, CA
Friends: 0 | Yes I meant 60 not 50 for those tires, a typo, sorry. Although I only have about 50K miles on my 2004, and have had a few different tires on it, I have not worn any of them down except for some alignment issue that wiped out on hydroedge tire. I drive sanely enought to get 48-49 mpg in a short 10 mile commute with lots of hills. I just kept searching for better handling and tried lots of combinations including the disaster that was the Scion take-offs. Nice wheels but mileage went down the tubes they were so heavy and wide. I would have/should have left the hydroedge tires on but I wiped one out when the alignment went crazy and I didn't catch it. Funny because this car has been aligned by more experts around town as I sought better handling so it was during a 6 month period where I didn't try a new alignment guru, lol. So when I say the car doesn't handle, I'm not talking slalom or anything. Just straight line stuff when you either encounter lots wavy deep and sometimes new rain grooves, or large passing vehicles, or 20 mph cross winds thru the mountains. That's where the car will literally just jump 6-12" suddenly from a side force. My wife sees and feels it without any wheel motion from me. Yeah the cars medocre handling stability is probably acceptable to some and I can see if you're not riding on a lot of grooved cement or unblocked cross-winds you might think the car is just fine. I did find out that the touring frt struts and springs (not sure about the springs) are standard after March 2005 Prius and that there's a different covering/spoiler under the engine on later models that could help with the handling. I did do one mod that seemed to help more than tires and that was using rubber wedges to stiffen the front coils. I took them out when I suspected an issue with my hydroedge wear. Now I see there are lots of stiffer springs available but they all seem to lower the car. Another mod I did back in 2004 was that I added an air dam at the very front of the car all across the bumper. While it was not really ideal for aerodyamics it did reduce lift and made the car track better. I probably should not have given up on persuing that because it didn't seem to affect mileage at all. I have played the tire pressure game to infinity and know about the 2 psi difference as well as trying higher differences. The car is now pretty bad with these Falkens so not much is going overcome that. They exaggerate the effect of road grooves even more. They are the only tire I've found that felt more stable at higher pressure, like 42/40. All the others seemed better at normal pressures where the contact patch was not reduced. So out of all the suspension parts and other fixes available, I'm curious which ones worked the best with owners that complained about wandering and straight line stability? |
| | #92 | |
| Junior Member Join Date: Aug 2007
I took it back a few weeks after purchase asking for an alignment. The female tech took it for a test drive with me on a dead straight road and noted no wander, nor did I. (Of course it had to make a monkey out of me!) So they did not want to perform an alignment on it. She mentioned that being a light car with a high profile, it would suffer the effects of crosswinds more than other vehicles, but it does it in dead calm on newly paved highways as well. I'm going for new tires Monday and will get a full alignment as part of that process. Between getting rid of the crap rubber that came with the vehicle and the alignment, I expect it to hold a straight line better. | |
| | #93 |
| Senior Member Join Date: Dec 2006 Location: Columbia, SC
My Car: 2007 Prius Model: Package: #2 Thanks: 10
Friends: 0 | Ask for a before/after printout of the alignment and post the values here. Some cars have trouble with the rear alignment, and alignment shops generally don't touch that. That problem has to be corrected with shims. The only way to know is to compare your values to the specs to see where they fall. |
| | #94 | |
Come to think of it, I probably saw that in the "what you need, what you don't" maintenance thread. It certainly would be nice to have the definitive, unequivocal answer to this once and for all. What does the shop manual say? | |
| | #95 | |
My Car: 2007 Prius Model: Package: #6 Thanks: 289
Friends: 11 | Quote:
More details in this thread: 2007 Model Alignment issues | |
| | #96 | |
Our cars are almost dangerous at times and Toyota either can't or won't listen. My opinion is that if they acknowledge this, they leave themselve open for litigation so they just go on denying it and force us to search all over the place for solutions that probably don't exist. My car is now better thanks to later model frt struts and touring edition anti-sway bars. It's still not what I would call good, but it's improving at my expense ($650 this time). Now I'll be shelling out for yet another set of tires because the Falkens accentuate all these bad characteristics of my car. So my $28K (plus another $2k in "improvements") car still handles worse than the $10K crappy Kia I rented this weekend. I'm not kidding. That cheap car tracked better than my $28K Prius. A lot better. | |
| | #97 |
Friends: 0 | I took my 2007 Prius to a local shop that seems savvy. The printout shows the right rear wheel toe-in wayyyyyyy out of spec, which accounts for the screwy driving pattern of this vehicle. See the attached scans. Unfortunately, they need to order the square shim kit for the rear axle and I need to take a trip in the car before it will come in, so more damage to my new tires will ensue. At least now I know for sure what has been going on, and the dealer was backpeddling from giving me a free alignment. At least when I return it will be done properly. |
| | #98 | |
Yours is similar but a bit worse than mine was. I couldn't get the dealer to fix mine either. | |
| | #99 | |
I'll post the results when the shim kit comes in and I get back to take the car in. | |
| higher, speeds, unstable |
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/55978-unstable-higher-speeds.html | ||||
| Technorati: Discussion about “Unstable at higher speeds” | This thread | Refback | 11-25-2008 08:49 PM | |
| Why is Prius unstable in windy conditions? | nickfromny | Gen II Prius Main Forum | 52 | 04-10-2008 10:54 AM |
| Stealth Driving at higher speeds today | saminjax | Gen II Prius Main Forum | 3 | 04-05-2008 10:26 PM |
| Oil Troubles From a Politically Unstable Country (That's Not In the Middle East) | boulder_bum | Prius and Hybrid News | 1 | 06-02-2007 02:25 AM |
| PriusChat website unstable | qbee42 | PriusChat Website Questions | 8 | 04-04-2007 02:21 PM |
| Prius fuel economy at higher speeds tested | clett | Prius and Hybrid News | 16 | 06-21-2006 12:38 PM |
