This is a discussion on Hybrid batteries and COLD within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Do we block the top section, or the bottom...or both?...
Old 01-02-2009, 10:39 PM   #11
lenjack
Default Re: Hybrid batteries and COLD
lenjack is offline
Old 01-03-2009, 12:24 AM   #12
Celtic Blue
Celtic Blue's Avatar
What I've gleaned from others is that it is supposedly safe to do both as long as temps don't exceed 60 F. However, without a Scangauge this is running blind (I don't have one at present.) It's my understanding that some fans will kick on if something gets too warm. Since I've never heard any of them, come on it appears that I've not pushed anything too far.
Top grill blocking should be safe regardless according to others I've read (although I would remove it in summer) so I did it first. Adding the bottom grill blocking when temps will stay below 60 is what I've picked up from others. Some do total blocks of the bottom grill, I blocked 4 of 5 lower grill slots. In doing so my ambient air temp. indication from the lower grill still appears to be reasonably accurate, and I know there is some circulation. I expect to begin removing some of the blocking around March 1.
Celtic Blue is offline
Old 01-03-2009, 09:15 AM   #13
DaveinOlyWA
3rd Time was Solariffic!!
DaveinOlyWA's Avatar
i block it all at temps under 60ºF
DaveinOlyWA is offline
batteries, lithium, nimh
Newsweek on Hybrid batteries priusisourfamilygashog Gen II Prius Main Forum 29 06-07-2008 04:06 PM
Hybrid batteries connections mrbigh Prius and Hybrid News 4 12-06-2006 01:53 PM
Hybrid batteries vs. the environment Rancid13 Gen II Prius Main Forum 21 06-28-2006 01:47 PM
Does winter (cold) storage affect the batteries? Jeri Gen II Prius Main Forum 4 12-17-2004 10:04 PM
hybrid batteries eak354 Prius and Hybrid News 8 06-10-2004 12:00 PM
