This is a discussion on Prius 2002 gas engine has developed loud noise within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; My 2002 Prius has developed a loud noise from the gas engine. It has 130,000 miles on it. The small ...
Old 01-07-2009, 11:04 AM   #1
chithanh119
Package: Pioneer #1
Default Prius 2002 gas engine has developed loud noise
The small check engine light is on.
Has anyone had a similar problem?
Thanks,
Billy
chithanh119 is offline
Old 01-07-2009, 11:51 AM   #2
Mjolinor
My Car: 2002 Prius
Default Re: Prius 2002 gas engine has developed loud noise
More information is needed like what sort of noise, revs related, when it's working, when it's ticking over, high pitch low pitch.
How did it start? Have you run out of oil or coolant with it.
You can probably get some good feedback on the fault but a lot more info is needed.
Mjolinor is offline
2002, developed, engine, gas, loud, noise, prius
Loud noise after car stops vemvim Gen II Prius Main Forum 5 01-25-2008 05:45 PM
non touring 07 tire noise LOUD priussoris Gen II Prius Technical Discussion 1 05-01-2007 08:57 AM
loud noise while braking and or coasting statultra Gen II Prius Technical Discussion 0 02-27-2007 09:37 PM
loud fan noise after long downhill using B Paul R. Haller Gen II Prius Care, Maintenance and Troubleshooting 7 08-16-2006 06:15 AM
LOUD NOISE...POW propking Gen II Prius Main Forum 6 03-30-2005 11:30 PM
Content Relevant URLs by vBSEO 3.3.0
