HV Battery Pre-Heat... Anybody tried it?
Old 02-02-2010, 01:40 PM   #51
orange4boy's Avatar
My Car: 2003 Prius
Package: Base (Canada)
Default Re: HV Battery Pre-Heat... Anybody tried it?
In my case I'm just busy with other projects. Too many pots on the stove.
I'm determined to do it though.
My current idea is to plot the regen amps, SOC, L/100 from the Graham scanner on one particular hill in my area.
There may be too much noise and variation to make a good comparison. One thing I'll have to contend with is that the battery "stores mpg" If you don't end up with the same SOC at the end your trip, the numbers will be difficult to digest. I will have to start lerning how to even out the SOC.
An A-B-A test would be impossible, really.
Ideas are welcome.
Transaxle preheat thread
orange4boy is offline
Old 02-02-2010, 03:06 PM   #52
PaulHS's Avatar
Thanks for responding. And I appreciate your determination.
A few questions.
1. I'm not familiar with a Graham scanner. I presume it has recording capability?
2. You are plotting your parameters to develop a baseline?
3. What is the significance of the hill in your experiment?
4. How will you correlate these parameters with HV battery temperature?
5. Is there a reason for not including initial ambient temperatures?
6. Wouldn't direct temp measurements of the HV battery accomplish your goal?
7. Evidence indicates that raising the battery temp from "sub-optimal to optimal" may require from one to three hours, depending on initial ambient temps, on an unmodified car. How will you deal with that?
8. What method are you currently considering for pre-heating?
Sorry if it seems I am bombarding you with questions but I don't quite understand how you plan to proceed.
Paul
PaulHS is offline
Old 02-02-2010, 05:07 PM   #53
orange4boy's Avatar
My Car: 2003 Prius
I have already started to gather my baseline mpg data. ambient air, road condition, battery temps, SOC, MPG. (wind is usually not significant because of forest lined roads)
The Graham scanner is a gen 1 data display/logger which gathers data from 50 sensors and displays 4 outputs at a time.
Connects to Vehicle using Existing OBD-II Data Link Connector 3 (DLC3)
Communicates with Vehicle ECUs using ISO9141-2 and ISO14230 (KWP) Protocols
Retrieves and Displays Data on Operation of Hybrid System, Engine, Battery, etc.
More than 50 Data Items available from Engine, Battery and Hybrid Vehicle ECUs
Logs Data via a Serial Port to a computer or PDA for Spreadsheet Graphing
Retrieves and Optionally Clears Diagnostic Trouble Codes
Generously lent from Bob Wilson's "Tool library"
I was thinking of using the hill to log regen amps and SOC. I know the computer allows the battery to take more amps when it's warm so I want to see if warming makes a difference in SOC.
I have a battery warmer wrap intended for lead acid which I hope to install between the battery housing and the body. I still have to do more exploration on that though.
Currently placing the blanket on top does heat the inside of the compartment and the top of the battery as shown by the scanner but it can't possibly do a good job of even heating in that position.
I may start a new thread to document it. May be a couple of weeks before I can get to it though.
Thanked by:
PaulHS (02-03-2010)
Old 02-03-2010, 06:41 AM   #54
PaulHS's Avatar
I'll be watching for your results. Thanks!
PaulHS is offline
battery, preheat
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/57752-hv-battery-pre-heat-anybody-tried.html
Pre-heating the Prius Transaxle and Engine for better fuel economy - Page 7 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-13-2011 09:41 AM
How To Install Car Cooling Fans This thread Trackback 02-09-2011 05:06 PM
Battery heating for EV efficiency - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 12-19-2010 04:26 PM
Pre-heating the Prius Transaxle and Engine for better fuel economy - Page 2 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 10-04-2010 05:03 AM
Pre-heating the Prius Transaxle and Engine for better fuel economy - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-01-2010 10:01 PM
Heat or A/C? p1cfl01 Newbie Forum 4 10-27-2008 09:06 PM
Automatic heat and battery condition ibiwisi Gen II Prius Technical Discussion 1 04-06-2008 07:57 PM
No heat! boriqua9719 Gen II Prius Care, Maintenance and Troubleshooting 4 02-07-2008 07:25 PM
Heat and battery life Birdums Gen II Prius Main Forum 6 08-07-2007 01:29 PM
Heat and AC tbstout2 Gen II Prius Fuel Economy 9 12-09-2005 05:14 PM
