This is a discussion on Transaxle Failure within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Originally Posted by efusco Realize that that tow hook on the front bumper is for emergencies only, when you can't ...
Transaxle Failure
LinkBack (2) Thread Tools
Old 02-28-2009, 04:19 PM   #21
ronhowell
ronhowell's Avatar
Default Re: Transaxle Failure
Originally Posted by efusco View Post
Realize that that tow hook on the front bumper is for emergencies only, when you can't get under the car to hook up for proper towing.
Yes indeed! I certainly hope you had the tow-truck driver lift the front wheels onto his carrier so only the rear wheels were in ground contact when your car was towed.
ronhowell is online now
Old 02-28-2009, 05:01 PM   #22
hobbit
hobbit's Avatar
The front wheels would be locked with the parking pawl. The
rear wheels *might* be held hard enough to drag by the parking
brake, but rolling the car forcefully is often enough to overcome
that and make the wheels turn.
_H*
hobbit is offline
Old 02-28-2009, 05:27 PM   #23
icarus
Advice that is worth exactly what you pay for it,,, but.
If this were my car, and it had just under gone a major failure of a pretty reliable component,,, I would consider a second opinion at a minimum, and certainly a second estimate. I would also look carefully for any TSBs that might be out there regarding this particular problem with this year/model etc.
It is always possible that some small failure is causing the person doing the diagnoses to conclude that "the transaxle" has failed, when in realit it might be a servo or a sensor or a left handed muffler bearing in the trans.
It just seems that with repairs of this magnitude some extra caution might be warranted.
Icarus
icarus is offline
Old 03-01-2009, 04:37 PM   #24
dailyphotofix
dailyphotofix's Avatar
Icarus
Yes, I was very hesitant before actually purchasing the transaxle...but I spoke with the mechanic at the dealership and he said that he checked each of the parts individually for the faults since all the different codes came up and the transaxle came up as the part with the failure. Also, it was pretty obvious that the failure was the transaxle because when the warning lights came on the car would vibrate and shutter really bad upon acceleration until the gas engine kicked in and it would also make a really strange noise upon decelleration. With the combination of obvious noises, cars behaviour, warning lights, and diagnoisis of the mechanic I am 99.9% sure that it is the transaxle. I am still going to do more diagnostics myself as I am working on the car. I obtained the toyota factory manuals online which are quite extensive in giving the spefications and steps for testing and repairing each part of the car, so those are helping me out a lot.
I did not get much done this weekend as I was really busy with work. I should have the transaxle this week and Saturday and Sunday I will be working on it all day...so I will have a lot of photos for you after that!
dailyphotofix is offline
Old 03-05-2009, 01:50 AM   #25
dailyphotofix
Just a quick note...I was browsing through the manuals I bought and found this little tidbit about one of the codes that came up:
"With the power switch's power mode changed to ON (IG),
disconnect the battery. If the key is not in the key slot
during reconnection, DTC B2799 may be output."
I did disconnect the battery and replace it without the key in the slot while I was trying to troubleshoot when the car broke down.
That may be the explanation for that code.
Old 03-06-2009, 05:33 PM   #26
dailyphotofix
The transaxle has been delayed...it will not be here until Tuesday. Looks like its going to be one more weekend before I can get it put in.
Good news is I have a couple more friends who are interested in helping me out with it so I should have plenty of hands to work with.
-Peter
Old 03-06-2009, 07:08 PM   #27
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Have you done any resistance checks in an effort to satisfy yourself that the existing transaxle actually needs to be replaced? You won't be happy if you go to the trouble of installing the replacement, only to find out there's no improvement...
Patrick Wong is offline
Old 03-06-2009, 09:32 PM   #28
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
Hobbit you really ought to go cross country (again) and get in on this project. Big Bear is lovely in the springtime...
tochatihu is offline
Old 03-06-2009, 11:26 PM   #29
dailyphotofix
I have no done the resistance checks yet. I am planning on doing them tomorrow while I am working on my other car (81' VW Veggie/Diesel Rabbit).
Does anyone know if I need a gasket kit for replacing the transaxle? I guess I could call Art's they would probably know...
Old 03-06-2009, 11:27 PM   #30
dailyphotofix
It is! Well usually. It was nice and warm last week...now it is 29 degrees outside and I am freezing my butt off. I guess it is good for the skiers, keeps the snow around longer.
p0a09, repair, replacement, transaxle, transmission
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/58920-transaxle-failure.html
GreenHybrid - Hybrid Cars This thread Refback 03-15-2009 10:39 AM
Fascinating NHW20 removal at PriusChat - GreenHybrid - Hybrid Cars This thread Refback 03-15-2009 07:22 AM
Changing Transaxle oil Weinerneck Gen II Prius Care, Maintenance and Troubleshooting 163 Yesterday 05:12 PM
Transaxle Oil Analysis ScottY Gen II Prius Care, Maintenance and Troubleshooting 135 11-13-2009 12:30 PM
'01 transaxle questions ozron Gen II Prius Technical Discussion 18 03-02-2009 04:44 PM
Transaxle Replacement Patrick Wong Gen II Prius Technical Discussion 6 10-12-2008 10:19 PM
