| This is a discussion on Gen II Brake Life - 83K+? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; As a new owner, I just got my 2009 Pkg 3 last week, where do I look to see the ... |
| | #21 |
| Junior Member Join Date: Jul 2009 Location: Burlington, NC
My Car: 2009 Prius Model: N/A Package: #3 Thanks: 0
Friends: 0 | As a new owner, I just got my 2009 Pkg 3 last week, where do I look to see the regeneration current value? |
| | #22 |
| Senior Member Join Date: Feb 2009 Location: Western Washington
My Car: 2010 Prius Model: II Package: No Package Thanks: 22
Friends: 0 | Not only is it normal on a Prius, it is also possible on pre-hybrids, depending on driving conditions and style. My two most recent pre-hybrids went just over 100k and 90k on their original pads. The wife did slightly better on her car, despite a higher fraction of city driving than I put on mine. |
| | #23 | |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 229
Friends: 23 | Quote:
| | #24 |
| Senior Member Join Date: Mar 2009 Location: USA
My Car: 2009 Prius Model: Package: #2 Thanks: 246
Friends: 19 | |
| | #25 |
| 2004 2009 prii dual owner Join Date: May 2004 Location: Indiana and Nevada
My Car: 2004 Prius Model: N/A Package: #9 Thanks: 0
Friends: 0 | i have 120000miles on my 04 with the original pads still in use...we had just pulled them off to replace wheel bearing and they still have about 1/2 the life left in them...we do city/country driving about 50/50 |
| | #26 | |
| High Fiber Member Join Date: Jun 2005 Location: South OC So Cal & the Flathead Valley MT
My Car: 2004 Prius Model: Package: #9 Thanks: 15
Friends: 12 | Quote:
| | #27 |
Friends: 59 | That's an interesting Prius info. Brake pads last longer than the wheel bearing! |
| | #28 | |
Friends: 1 | Quote:
I had my driver side front bearing replaced a week ago at 94K. Started making noise 2 weeks earlier. On and off, usually more in the first 10 minutes of driving but sometimes really ugly any time for a few seconds. Fortunately I had no long trips in those 2 weeks, nothing more than 10 miles per trip, mostly 40 MPH and under. They noted 40% wear on the front pads, 20% on the rear. So I figure my pads will be good for 175K to 200K miles. I was kinda hoping the noise was just the TripleTreds wearing (about 70K miles and down to the wear bars) so I brought in the OEMs to put on the summer rims. They have maybe 7K miles and I don't like them but can't really afford to buy new summer tires right now. They said I had a bad bearing (yeah, in my heart, I was pretty sure it was a bearing but a guy's wallet can HOPE, yes??), he even showed me the 'push/pull' test and yeah I could see movement from 20 feet away. On the sheet it was noted that he did not drive the car prior to replacing the bearing, noise gone during test drive. Specifically used the word "gone". Only HE never heard it. If you don't hear a scraping noise after bearing replacement AND you didn't hear it before replacement, was it really there?
__________________ Bruce Mine: Driftwood '04 BC 24 Sept 2004 - added: mudflaps, door edge guards, side panel moldings, Coastal Tech EV switch, OEM Integrity tires, WeatherTech window deflectors. Last tank - 14 Jul '09: 728.9 miles - MFD MPG: 56.0 Actuals Lifetime: 93,087.3 miles, 48.90 MPG. Wife's: Barcelona '06 #7 May 2006 - added: front mudflaps, Coastal Tech EV switch. OEM Integrity tires. Last tank - 21 May '09: 419.4 miles - MFD MPG: 46.7 Actuals Lifetime: 31571.4 miles, 44.82 MPG. | |
| | #29 |
Friends: 59 | Come to think of it.... It is amazing that the brake pads would last through 3-5 set of tires. |
| 83k, brake, gen, life |
| Brake Life??? | tomforst | Gen II Prius Main Forum | 17 | 05-04-2009 08:26 PM |
| Brake, Brake warning, ABS, VSC appear | popptj | Gen II Prius Care, Maintenance and Troubleshooting | 5 | 12-22-2008 08:08 PM |
| Is the Rear Brake Applied Everytime I brake? | GusTheCat | Gen II Prius Technical Discussion | 5 | 11-21-2008 11:13 PM |
| ABS brake warning on 2007 Prius leading to brake failure | adk235 | Gen II Prius Care, Maintenance and Troubleshooting | 4 | 08-05-2008 07:02 PM |
| A Day in a Life | hycamguy07 | Fred's House of Pancakes | 13 | 06-14-2006 01:42 PM |
