This is a discussion on Gen II Brake Life - 83K+? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I have 135,000 miles on my '04, dealer indicated at oil change, last week, that I have 65% of my ...
Old 08-12-2009, 10:59 PM   #31
artie
Default Re: Gen II Brake Life - 83K+?
I have 135,000 miles on my '04, dealer indicated at oil change, last week, that I have 65% of my brakes remaining on both front and rear...however, a few months ago I also had the front driver's side wheel bearing replaced (first repair ever) and I was shocked at the cost, dealer wanted $600 or so, eventually charged me $400, as a "personal favor" (don't ask me, I don't even know the guy). I think I'll stop reading this particular forum, however...too many scary things have been reported as going wrong...back to modifications.
artie is offline
Old 08-13-2009, 11:13 AM   #32
richard schumacher
Destination: Eschaton
Originally Posted by 2009Prius View Post
So if I see a stop sign ahead, instead of coasting regen at about 10 ~ 20A, I should glide and then at the last moment brake regen at 60A?
Ehh, I'd say not. That makes it too easy to misjudge the situation and force you to use the friction brakes more near the end.
richard schumacher is offline
Old 08-13-2009, 08:06 PM   #33
sorka
My '95 Lexus SC400 has only had it's brake pads changed once in it's 284K mile life. I've flushed the brake fluid 3 times though with mobil 1.
sorka is offline
Old 08-13-2009, 10:13 PM   #34
hobbit
hobbit's Avatar
Close to factory-thickness meat on mine, front and rear, at
110+ K so far. I'm continuing to be mildly paranoid about wheel
bearings but haven't detected any play in any of them yet.
Long, *even* braking is the best strategy for collecting regen,
as it keeps battery currents low and steady like a good charging
algorithm. It takes a little more planning ahead but if you look
where the stop point ultimately will be [which may be a moving
target in traffic!] and modulate foot pressure to meet that,
it works well.
_H*
hobbit is offline
The Following 2 Users Say Thank You to hobbit For This Useful Post:
krmcg (08-13-2009), whodat (09-05-2009)
83k, brake, gen, life
Brake Life??? tomforst Gen II Prius Main Forum 17 05-04-2009 08:26 PM
Brake, Brake warning, ABS, VSC appear popptj Gen II Prius Care, Maintenance and Troubleshooting 5 12-22-2008 08:08 PM
Is the Rear Brake Applied Everytime I brake? GusTheCat Gen II Prius Technical Discussion 5 11-21-2008 11:13 PM
ABS brake warning on 2007 Prius leading to brake failure adk235 Gen II Prius Care, Maintenance and Troubleshooting 4 08-05-2008 07:02 PM
A Day in a Life hycamguy07 Fred's House of Pancakes 13 06-14-2006 01:42 PM
