This is a discussion on Gen II Brake Life - 83K+? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Just bought a used Gen II `04 and learned that while the previous owner replaced the brake fluid at 46K, ...
Old 07-21-2009, 10:56 PM   #1
Schmullis
Package: Navigation
Default Gen II Brake Life - 83K+?
Just bought a used Gen II `04 and learned that while the previous owner replaced the brake fluid at 46K, the car still has the ORIGINAL pads on the front. Seems to stop OK, but I've never heard of a car going 83K on the same pads. Any experience if this is normal?
Thanks for a reply.
Schmullis is offline
Old 07-21-2009, 11:21 PM   #2
wfolta
Default Re: Gen II Brake Life - 83K+?
With regenerative braking doing most of your stopping work, it doesn't seem unreasonable to expect to go 5-10x longer between brake pads. I've read about it here in the forums, and I'm looking forward to seeing the effect over the years myself.
wfolta is online now
Old 07-21-2009, 11:24 PM   #3
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Yup, seems reasonable. If you brake lightly, regen takes most of the work so the pads are really only there to slow down the car for the last 8mph and keep the car stopped at a light.
Tideland Prius is offline
Old 07-21-2009, 11:37 PM   #4
john1701a
john1701a's Avatar
Mine had 118K on them when I sold the 2004 in May.
john1701a is offline
Old 07-21-2009, 11:48 PM   #5
usbseawolf2000
HSD PhD
usbseawolf2000's Avatar
Friends: 59
I have 101k miles and the front pads are not even half way yet. I would guess it still has over 70% left.
usbseawolf2000 is offline
Old 07-22-2009, 12:57 AM   #6
V8Cobrakid
Friends: 5
with my rims and my driving habits.. i finally need to change my brakes. i'm at about 124336 miles or.. something like that. the fronts are making noise... i have yet to really look into it.. i figured they've had their use.
V8Cobrakid is offline
Old 07-22-2009, 02:15 AM   #7
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 11
I just did my 30k service at 29,616 miles. I measured the front pads and the thinnest of the two was 9.7mm. The standard thickness is 11mm, so I have used 1.3mm in 29,616 miles. The minimum thickness is 1.0mm. So, if you extrapolate, I could get as much as 227k miles from the original front brake pads.
dogfriend is online now
Old 07-22-2009, 09:04 AM   #8
archae86
Yes, but the definition of "brake lightly" varies rather drastically with speed in terms of how it feels. I am disappointed that Toyota does not include any kind of display to clarify when you have exceeded regeneration limit and are actually using the friction brakes. However if you watch the battery current display on a scan gauge while gently varying the brake force, you can find the limit.
At 25 mph it is really, really easy to stay in pure regeneration. By contrast, at 75 mph the regeneration limit represents a very modest deceleration rate.
I would love to hear the truth from actual Toyota technicians who see a lot of brake pads, but I suspect that the rate of wear varies quite drastically from owner to owner, being driven both by driving conditions and owner habits. (even more so than with conventional systems)
archae86 is offline
Old 07-22-2009, 09:12 AM   #9
john1701a
john1701a's Avatar
They do. It's on the new ECO-METER.
Remember what things were like way back in 2003 when the Iconic model was rolled out. Even the simple handheld GPS was just a dream still. A lot has changed since then.
Old 07-22-2009, 09:14 AM   #10
Very few posters on PC have reported replacing front brakes before 100K miles. While it isn't a scientific survey, it does give a good indication of long brake life.
I suspect most Prius drivers are not heavy brake users. It goes against the whole reason to own a Prius.
83k, brake, gen, life
Brake Life??? tomforst Gen II Prius Main Forum 17 05-04-2009 08:26 PM
Brake, Brake warning, ABS, VSC appear popptj Gen II Prius Care, Maintenance and Troubleshooting 5 12-22-2008 08:08 PM
Is the Rear Brake Applied Everytime I brake? GusTheCat Gen II Prius Technical Discussion 5 11-21-2008 11:13 PM
ABS brake warning on 2007 Prius leading to brake failure adk235 Gen II Prius Care, Maintenance and Troubleshooting 4 08-05-2008 07:02 PM
A Day in a Life hycamguy07 Fred's House of Pancakes 13 06-14-2006 01:42 PM
