| This is a discussion on 2004 Toyota Prius with 9000 damage within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Should you repair a 2004 Toyota Prius with 9000 damage including replacement of the side pillar between the front and ... |
| Junior Member Join Date: Jul 2009 Location: Los Angeles
My Car: 2008 Prius Model: II Package: Solar Roof Thanks: 0
Friends: 0 | Should you repair a 2004 Toyota Prius with 9000 damage including replacement of the side pillar between the front and rear right-side windows? __________________ You win some, you lose some, you wreck some. |
My Car: 2007 Prius Model: N/A Package: #4 Thanks: 54
Friends: 45 | Well, you'll need to figure out the market value of the car when repaired; use kbb.com and look for the private party value or dealer trade-in value, depending upon whether you can sell the car yourself or must rely upon a trade-in. Then call a local salvage yard to determine the value of the unrepaired car if towed to the salvage yard. If the difference between those two numbers is more than $9K then it would be potentially worthwhile to repair. |
| Rare Under-30 Priuschat Member Join Date: Jun 2008 Location: Chicago, IL
My Car: 2008 Prius Model: N/A Package: #3 Touring Thanks: 13
Friends: 18 | A better question to ask is whether the frame is still within spec. I wouldn't go through the trouble of fixing a car whose unibody had been seriously distorted because the car will never drive the same. That said, it isn't hard to put $9k of damage on a Prius - State Farm had a little booth at the auto show a couple years back with a picture of a Prius which someone had rear ended and asked people to guess how much damage there was. The whole back of the car had been crumpled in and the glass shattered - apparently it was $12k in damage. |
My Car: 2007 Prius Model: Package: #2 Thanks: 7
Friends: 3 | Quote:
| Member Join Date: Apr 2007
Friends: 0 | No. A 2004 Prius is likely only worth $9000 without accident damage. After such major repairs this will show up on a carfax making it difficult to sell for anything close to this. |
| Junior Member Join Date: Jul 2009 Location: Burlington, NC
My Car: 2009 Prius Model: N/A Package: #3 Thanks: 0
Friends: 0 | I bought my daughter's 2004 Pkg 6 for less than $9K. So I think you are underwater or nearly so based on mileage. |
| Member Join Date: Dec 2006
My Car: Model: Package: Thanks: 5
Friends: 0 | To find out what your car will be worth after the repair, get the "trade-in value" from Kelley's and Edmund. Take the lower number and subtract at least $2000. Then, remember that the $9000 is an estimate, subject to increase after more damage is discovered. Then factor in that Carfax will show an extensive damage accident, making the car harder to sell. Then remember that little things like the radio may not work right and require specialized repair. Then remember that an accident can cause occult damage. Another chatter bought a damaged Prius. 20,000 later he broke a piston. A piece of the intake manifold was found in the engine. It was theorized that the manifold was cracked in the accident and that the piece broke off after 20,000 miles. Enjoy! |
| 2004, 9000, damage, prius, toyota |
| 2004-2009 Toyota Prius! | JoshuaNixon | Newbie Forum | 8 | 02-09-2009 07:35 PM |
| Take 2: AutoWeek: 2004 Toyota Prius: Wrap-up | IsrAmeriPrius | Prius and Hybrid News | 2 | 11-14-2005 11:35 PM |
| 2004 Toyota Prius for sale in Bay Area | dahl | Private Sales | 3 | 06-09-2005 12:01 PM |
| Long Term: 2004 Toyota Prius | Tideland Prius | Prius and Hybrid News | 1 | 06-03-2005 01:01 PM |
| AutoWeek: 2004 Toyota Prius: Wrap-up | IsrAmeriPrius | Prius and Hybrid News | 0 | 12-31-1969 07:00 PM |
