| This is a discussion on anyway to reset airbag control module SDM DIY within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; recently I changed my airbags (roof and chair) the airbag light is on and disconnecting the battery and the OBD ... |
| Member Join Date: Aug 2009 Location: NY 11020
My Car: 2005 Prius Model: N/A Package: Navigation Thanks: 13
Friends: 1 | recently I changed my airbags (roof and chair) the airbag light is on and disconnecting the battery and the OBD II does not turn it off so I found out the SDM has to be reset or according to dealer changed. well I found some websites and ebay that offer to reset it for 60$ or so Is there anyway i can do it my self? I have an ELM237 scantool just incase. I would appreciate all the good answers! |
| Junior Member Join Date: Aug 2009 Location: Chichester, NH
My Car: 2007 Prius Model: N/A Package: #2 Thanks: 0
Friends: 1 | I am assuming you replaced airbags because they blew. If that is the case then yes, you will have to send it out. I have had rare cases, mostly Fords, that a factory scantool can clear it, but usually once it has made the decision to deploy, that is it until one of the companies that resets them does it. Even then it is a crapshoot. The things that fail on them and cant be fixed are the accelerometers if built in, and the extreme heat that burns chips and melts solder from blowing the airbags. I will say the place that used to do the airbag modules for the last shop i worked at were fixing every 2 out of 3! If there is anyone here that works for a company that resets them, I'd love to know how you do it too! |
| The Following User Says Thank You to ragman For This Useful Post: | doctorman (08-29-2009) |
Friends: 1 | Quote:
I just bought one and will send mine in for refund for the net total of 55$ + my postage. Its funny how people working in the dealer ship dont know this info. or probably they do but not allowed to send their business out... wonder what the dealers do with the blown control modules?! | |
| airbag, control, diy, module, reset, sdm |
| Boiler Reset Control | Freedom | Environmental Discussion | 14 | 07-13-2009 01:02 PM |
| Bluetooth module replaced | Clasimodo | Gen II Prius Audio and Electronics | 2 | 06-22-2006 06:24 PM |
| 25HP Performance Module? | acousticbiker | Gen II Prius Main Forum | 7 | 01-27-2006 08:17 AM |
| EV module oem part? | tootallrls | Gen II Prius Main Forum | 5 | 11-27-2005 11:16 AM |
| DRL Module? | Hytec | Gen II Prius Main Forum | 16 | 11-01-2004 09:34 PM |
