This is a discussion on Unusual Experiene - Any Answers? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; One day last week I was driving along, nothing unusual, when the radio suddenly went off. When I hit the ...
Old 09-07-2009, 04:15 PM   #1
Tomel51
Default Unusual Experiene - Any Answers?
One day last week I was driving along, nothing unusual, when the radio suddenly went off. When I hit the Audio Button on the MFD, the screen said "Audio Off". I then hit the Climate button and it said the "Check the A/C Connection" (the A/C, unlike the radio, was still operating). I pulled in to a nearby parking lot and turned off the car. After about 10 seconds I turned the car back on and everything was back to normal. Radio and A/C working and no messages on the MFD. This problem has not recurred during the past week.
Any thoughts as to what happened? Should I take the car in to Toyota and have them check it out? The vehicle is a new '09 with only about 6,000 miles.
Thanks for any input or thoughts.
Tomel51 is offline
Old 09-07-2009, 04:19 PM   #2
bluemonday
bluemonday's Avatar
Model: II
Default Re: Unusual Experiene - Any Answers?
Ruh roh, I remember reading something about this recently and it wasn't a good sign. I think it signals a MFD problem that has plagued some people. But this is just my memory about a problem I don't have, so I'd suggest a search.
bluemonday is offline
Old 09-07-2009, 06:25 PM   #3
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
...Any thoughts as to what happened? Should I take the car in to Toyota and have them check it out? The vehicle is a new '09 with only about 6,000 miles...
It sounds like your MFD has an intermittent connection within. I suggest that you take a good digital photo of the screen when the problem happens so that you have evidence that your car has a problem.
Otherwise, if you take your car to your dealer, the MFD likely will work just fine when the tech looks at it, s/he will note NTF (no trouble found) and you will have just wasted your time (not to mention the service writer's and the tech's) without any action being taken.
Patrick Wong is offline
Old 09-08-2009, 10:04 AM   #4
Tomel51
I've been able to do some more research and found out about TSB EL002-05 which seems to describe the problem I encountered. However, that Technical Service Bulletin deals with the '04 Prius and I cannot find any reference to later Pri's having the same problem. In fact, the TSB says "A revised multi-display has been developed to resolve these conditions." Is anyone aware of someone with a later model Pri that had this problem?
Good idea about taking a pic of the display if the problem recurs. You're absolutely right about proving that the problem has occurred so that the Toyota tech will take some action other than looking at the display and saying everything's fine.
Tomel51 is offline
Old 09-08-2009, 10:33 AM   #5
richard schumacher
Destination: Eschaton
You're not alone. A few of these have cropped up recently. Who will be the first to tear one apart for diagnosis, as hobbit brilliantly did with the original design?
richard schumacher is online now
Old 09-08-2009, 05:58 PM   #6
jayman
I agree an intermittent or corroded connection is probably at fault. Usually, if you carefully pull the connector and reseat it, the problem will go away
jayman is online now
Old 09-08-2009, 06:40 PM   #7
a priori
Canonus Curiosus
a priori's Avatar
Model: V
Package: Adv. Technology
Friends: 18
Patrick's idea of taking a photo is great!
I caution you on just waiting before reporting the issue, though. You need to establish it happened during your warranty period. For someone with a 2009, this may not be an issue. All the same, I would write a letter, at a minimum, to your dealer. Explain the situation and advise you will be waiting to take a photo of the screen the next time it happens. When you take the photo, try to make it wide enough to encompass the ODO, or take a few so that you can see close up (if necessary) and the full dash (for the odometer reading).
Previous Prius: 2007 Silver Pine Mica Pkg #6. 29,492 miles.
Lifetime: 52.2 MPG; Last Rolling 12 Months: 53.4 MPG
Current Car: 2010 Blue Ribbon Metallic Prius V w/ AT Pkg. (from 5/25/09)
Lifetime City Mileage: . . . . . . . 57.7 MPG
Lifetime Highway Mileage: . . .56.8 MPG
Lifetime Combined Mileage:. .57.1 MPG @ 8,242 miles
Best Trip Odo: (778.7 mi at 20 mph): 60.6 MPG & (390.0mi at 47 mph): 64.5 MPG
a priori is offline
answers, experiene, unusual
A few answers to your questions... Prius Team Gen III 2010 Prius Main Forum 80 04-11-2009 08:53 AM
Answers from Tesla daniel Other Cars 128 03-20-2007 03:35 PM
Looking for a few answers before I buy greenatheart Gen II Prius Main Forum 1 02-11-2007 07:09 PM
Looking for a few answers before I buy greenatheart Gen II Prius Main Forum 11 02-11-2007 04:14 PM
Need some answers robinredbreast Gen II Prius Care, Maintenance and Troubleshooting 12 11-22-2004 12:29 PM
