| This is a discussion on Stage 4 question within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; So I understand how you need to do the idle check thing twice after the coolant reaches 70 C in ... |
Stage 4 question
| Junior Member Join Date: May 2008 Location: Cabin John, Md.
My Car: 2008 Prius Model: N/A Package: #5 Thanks: 1
Friends: 0 | So I understand how you need to do the idle check thing twice after the coolant reaches 70 C in order to get to stage 4. But I also know the engine will shut off even before reaching stage 4 if you start to glide above 34 mph. So let's say you're in stage 3 and you glide all the way to a stop from, say 35 mph. And you stay stopped (or less than 6 mph) for the required 7 seconds. Does this count as one of your "idle checks" needed to get to stage 4? I think not, but I don't know why. I also tried to put the stages ritual in a state diagram. See if this helps. Thanks, Rob
__________________ Lifetime FE: 56.5 mpg or 4.16 l/100 km over 17,089 miles Engine block heater, Coastaletech EV Mode switch, ScanGuage II, Rear bumper guard, Cargo net, Routed the AUX cable out the front drawer of the center console, Rear wiper cover mod Potomac Pedalers Touring Club (PPTC) Mid-Atlantic Off Road Enthusiasts (MORE) |
Friends: 37 | Only one idle check is required, but the engine must go from running while the vehicle is stopped for the 7 seconds until it shuts off. So, no, you can't glide from above 35mph to a stop and stay stopped and count as your idle check. What I do is glide to that stop, gun the ice with my foot on the brake to get it started, then while waiting for the light let the idle check occur. I am curious where you got the idea that 2 idle checks is required. BTW, cool diagram, I'd never seen that before.
Friends: 0 | Yes - one idle check - just a dumb mistake on my part. Thanks for your answer. Last edited by rokibler; 09-18-2009 at 09:47 PM. |
| question, stage |
| New HSD stage? | anne1965 | Gen III 2010 Prius Fuel Economy | 8 | 08-18-2009 11:27 AM |
| Stage II & stage III interchange | ibiwisi | Gen II Prius Technical Discussion | 4 | 04-04-2008 04:02 PM |
| Stage 4 | gazz | Gen II Prius Technical Discussion | 9 | 07-18-2007 07:28 AM |
| What stage is this? | walroose | Gen II Prius Technical Discussion | 11 | 06-20-2007 11:55 AM |
| 2 stage regen | gazz | Gen II Prius Fuel Economy | 10 | 05-23-2007 07:44 AM |
