This is a discussion on intermitant headlight on left side within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; On my 2006 Prius the left headlight is sometimes out and then on. I watched it go dim to on ...
Old 09-18-2009, 09:53 PM   #1
boggyman
Model: V
Default intermitant headlight on left side
On my 2006 Prius the left headlight is sometimes out and then on. I watched it go dim to on while the right side was on fully. any ideas? I know a new bulb is very expensive so I don't want to replace it if not necessary.
boggyman is offline
Old 09-21-2009, 12:04 PM   #2
derh2o
Default Re: intermitant headlight on left side
I had the same problem with a 2007 Prius. I took it to my dealer and they replaced both headlights at no cost even though only one light had the problem. they told me it was a known problem.
derh2o is offline
headlight, intermitant, left, side
FS: OEM Toyota Prius 2004-2008 heated side mirror glass left and right side exbauer Private Sales 3 11-02-2008 01:28 AM
I broke my left side mirror montenido Gen II Prius Care, Maintenance and Troubleshooting 8 02-14-2008 11:25 PM
Driver's side headlight goes on and off lilrdwgn Gen II Prius Technical Discussion 1 07-26-2006 01:37 AM
Left side door won't open from the inside jkash Gen II Prius Care, Maintenance and Troubleshooting 5 10-26-2005 02:52 PM
passenger side headlight higher than driver side alsgameroom Gen II Prius Care, Maintenance and Troubleshooting 7 10-21-2005 08:09 PM
