| This is a discussion on when will the ice kick in during acceleration within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I just bought a used 2007 prius. I'm in California and it is very warm. It seems like the ICE ... |
| Member Join Date: Sep 2009 Location: California
My Car: 2007 Prius Model: N/A Package: #5 Thanks: 0
Friends: 0 | I just bought a used 2007 prius. I'm in California and it is very warm. It seems like the ICE will kick on during the slightest acceleration from a stop even if I don't try to accelerate very fast. I wish it would have just a bit more pep at the start without the ice coming one.. I don't mind the ice coming on and realize it needs to at some point to recharge the batteries but in stop and go traffic or going down a road with many lights it would be nice to be able to go at a pace that the person behind me doesn't want to shoot me and still have the ice not come one.. I do notice that when the batteries are in the green you can do alot more with the electric motors.. |
| Sapphire of the Blue Sky Join Date: Apr 2007 Location: Virginia
My Car: 2007 Prius Model: N/A Package: #2 Thanks: 3
Friends: 0 | The less you accelerate with the batteries, the better mileage you'll get. The green batteries symbolizes the charge level it'll turn different colors based on how full or empty the batteries are. look at the number of bars on the battery, you'll see it'll have different colors based on how many bars it has. And to answer your question: the ice will kick in unless you wanna accelerate really slowly. That's what its designed to do for optimum mpg. Second-guessing the programming will only hurt your mpg. Last edited by Bob64; 09-24-2009 at 11:19 PM. |
Friends: 0 | |
Friends: 0 | Really slowly is probably the throttle position you have to push so the engine doesn't come on while the charge is blue Normal is any position after as soon as the ICE turns on + a little bit extra to eliminate it directing most of the electricity to the batteries instead of to the electric motors. Approx 1300rpm and up to approx 2400 rpm. Any higher and it'll probably be wasting gas due to pumping losses as well as the adjustment of fuel injection for more power instead of efficiency. Just accelerate at the same speed of traffic. Just don't purposely go slower so the engine doesn't come on. Because after awhile, the prius WILL FORCE the engine to come on at the SLIGHTEST push of the accelerator. Heres why using the battery is bad: Energy is lost converting mechanical energy into electric, then chemical energy, and then back into electrical and then back into mechanical. Think about it: the electricity comes from GAS. Converting gas to mechanical, then to electric, then to chemical, then back into electric, and then finally back into mechanical is even less efficient then simply leaving all those other conversions out and just use gas into mechanical energy LIKE IT WAS DESIGNED TO DO. The whole point of the battery is to capture BRAKING ENERGY: Which is the energy that would otherwise be LOST in the brake pads and converted to useless heat.
__________________ 2007 "Pirates of the Internet" Seaside Pearl Nicknamed "Souten" (蒼天) Japanese for Blue Sky. Named for the hope that its namesake will remain forever the same color as its exterior. Lifetime average MPG at 30037 miles: 64.6MPG Daily trip (13 miles each way) mpg : 64.3MPG Personal mpg record driving the above trip: 90.5MPG @ 86F ![]() Mods: 90% grill block EBH "Racing" Hubcaps Last edited by Bob64; 09-24-2009 at 11:39 PM. |
Friends: 0 | this is just creeping right.. I know it is hard to describe in words.. just seems like with the slightest push the ice kicks on.. |
| Senior Member Join Date: Mar 2009 Location: new york
My Car: 2006 Prius Model: Package: #2 Thanks: 4
Friends: 2 | Install an EV switch. |
Battery power accelerates ~three or five times as fast as creeping. If you really wanna figure this out, get/borrow a scangauge so you can tell exactly how much energy is coming from the battery. Last edited by Bob64; 09-24-2009 at 11:45 PM. | |
Friends: 0 | I have a scan gauge already.. I'm gonna hook it up tomorrow so I can monitor the load , rpm, and the battery like you said.. I've never been in the red.. never really seen less than half but once.. usually at 6 segments in the blue.. never been completely full to 8.. get to 7 green during city driving.. I guess the regeneration? from what I have seen and the fact I am on the freeway mostly at 65+ speeds I think these battery levels are pretty good... NO ?? Last edited by J_w73; 09-25-2009 at 12:10 AM. |
Friends: 0 | I have read this about the EV mode.. EV mode will automatically disengage when: your SOC reaches 2 bars; you step too hard on the accelerator; you reach 34 mph; or your battery gets too hot how much more accleration can you do in EV mode before the ICE kicks on |
Friends: 2 | Quote:
There is significant difference in the greater EV acceleration you can get with an EV mode switch. If you already drive gently, it feels like gentle ICE use and its easy to forget you're using EV mode and run the HV battery down to the red/magenta bars. In stop and go driving it takes a really long time to get back to 5-6 blue bars. At 65+ it wouldn't take so long, but in both cases the recharge has a big MPG hit. I've got an EV mode switch, but I've gotta say that I hardly use it any more. The conversion losses in energy going from ICE to HV battery and then on to MG1 to power the car just kill your FE/MPGs. FWIW, you can quickly drop out of EV mode at any speed or SOC (HV battery) level with a quick, half-throttle punch on the go-pedal. You don't seem particularly concerned about maxing your FE/MPGs, so you just might be one of the rare cases/people where heavy EV use and the attendant FE/MPG loss isn't an issue. Last edited by Rokeby; 09-25-2009 at 06:43 AM. | |
| acceleration, ice, kick |
| I did it and I didn't have to beat the wife or kick the dog | havanese_boy | Gen II Prius Audio and Electronics | 2 | 12-11-2007 11:20 PM |
| Like a swift kick in the... | !greenhousegas | Gen II Prius Main Forum | 0 | 05-15-2007 05:23 PM |
| When does the electro motor kick in? | zijlstra | Gen II Prius Main Forum | 7 | 04-24-2007 11:31 AM |
| How to Kick the Oil Habit | Rancid13 | Prius and Hybrid News | 0 | 10-25-2005 08:50 PM |
| Should I feel the Engine Kick on and off? | TimeFor | Gen II Prius Main Forum | 9 | 10-21-2004 01:09 PM |
