This is a discussion on remove gas bladder within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Is there any way to remove the gas bladder in the gen II and replace it with the steel tank ...
remove gas bladder
Old 10-04-2009, 03:26 PM   #1
biff44
Package: #3 Touring
Default remove gas bladder
Is there any way to remove the gas bladder in the gen II and replace it with the steel tank in the gen III? Would be a nice upgrade!
biff44 is offline
The Following User Says Thank You to biff44 For This Useful Post:
dave77 (10-08-2009)
Old 10-05-2009, 07:36 PM   #2
lenjack
Default Re: remove gas bladder
The number of changes you'd need to make to the fuel system, it's sensors, and to the numerous onboard computers, and the electrial system, would be overwhelming.Might be cheaper to buy a Generation 3!
lenjack is offline
The Following User Says Thank You to lenjack For This Useful Post:
dave77 (10-08-2009)
Old 10-05-2009, 08:59 PM   #3
ken1784
SuperMID designer
ken1784's Avatar
Package: G
Friends: 8
I believe gen III tank is plastic.
Is it legal to remove emission control device, such as a catalyst?
Ken@Japan
ken1784 is offline
The Following User Says Thank You to ken1784 For This Useful Post:
dave77 (10-08-2009)
Old 10-08-2009, 10:25 AM   #4
Ken@Japan
No. Tampering with or removing emission control devices is a federal offense.
The Following User Says Thank You to qbee42 For This Useful Post:
dave77 (10-08-2009)
Old 10-09-2009, 08:25 AM   #5
Sandy
Hippi Chick
Sandy's Avatar
Friends: 8
it would be a great idea to get rid of it
Sandy is offline
Old 10-09-2009, 10:08 AM   #6
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
You'd probably have to import a European or Japan spec Prius fuel tank along with the engine ECU for those regions (since the NA engine ECU can check integrity of the bladder system.) However the Europe or Japan engine ECU might not work well with the other ECUs, and as previously pointed out, this would be an illegal exercise...
Patrick Wong is offline
Old 10-09-2009, 10:34 AM   #7
NoMoShocks
Electrical Engineer
NoMoShocks's Avatar
There must be something wrong with my 2007 Prius. The feul tank bladder has never given me any greif at all. Please help me. Am I doing something wrong?
NoMoShocks is offline
Old 10-09-2009, 11:24 AM   #8
David Beale
David Beale's Avatar
Pearl works just fine as well. Yup, you have to be careful when filling with fuel. You can't just shove the nossle in and release the hounds!
But there are two "problems" here. An upitty fuel gauge with a mind of its' own as well as the fuel tank bladder.
Pearl has only spit back at me twice now, so I don't let the systems work on their own. I -carefully- put fuel into the car without relying on the nossle shutoff. You do it so infrequently, it's worth taking a few minutes more to do it right!
Edmonton Alberta
David Beale is offline
Old 10-09-2009, 12:11 PM   #9
Shawn Clark
Shawn Clark's Avatar
I'm not sure that the conversion would be illegal, in fact I doubt it would be at all. This is not a mandatory pollution control device instead it's an optional one. Putting in another tank that met regs should be legal. (The cat converter was mentioned, but the analogy would be in replacing it with another kind of cat that also met the regulatory requirements.)
However, as others have noted there is a bunch of sequencing and computer control around the tank space venting systems, so as a practical matter the conversion might not be doable.
Owners should be happy that we don't have to report a spill when the tank burps fuel. That would dampen the already thin enthusiasm for the bladder in a big hurry!
One of these days I'll get around to making the emergency venting device that I believe might fix "refusal to fill" situations.
Shawn Clark is offline
Old 10-12-2009, 11:32 AM   #10
David Beale
Actually the way the law is written it is illegal to replace any part of the emission control equipment with anything BUT stock parts or in California, with -CARB approved- parts. It was worded that way to stop "street tuners" from swapping in stuff that didn't perform as well re emissions.
If you replaced the tank with a European one you WOULD increase emissions, even if you got all the other evap. stuff working to the satisfaction of the car's computers, so it would still be illegal. The car is sold in the US and Canada as, I think it's worded, a ULEV. It wouldn't be with the other tank and evap. system. You can improve it but you can't make it worse, even if it still meets regs. unless you want to go through the approval process.
bladder, gas, remove
Bladder in Gen III or not? Bluebonnet2 Gen III 2010 Prius Main Forum 10 08-14-2009 12:34 PM
the gas bladder: exposed! galaxee Gen II Prius Technical Discussion 78 10-06-2008 12:09 PM
what is the bladder all about? swfoster2 Gen II Prius Main Forum 7 10-18-2007 12:40 AM
To remove or not to remove door panels DBM Gen II Prius Modifications 4 06-27-2005 10:24 AM
Fuel Bladder Tideland Prius Gen II Prius Main Forum 2 10-16-2004 09:57 PM
