This is a discussion on My Prius has the STINCH! within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; I bought a '06 with 67K miles on the cheap cause it had an odor like cat pee or vomit ...
Old 10-13-2009, 10:10 PM   #1
tech
Default My Prius has the STINCH!
I bought a '06 with 67K miles on the cheap cause it had an odor like cat pee or vomit inside. Thought I could get smell out with a little elbow grease and cleaner. After a week of hard labor, sun-ing, airing out & fumigating, I read the "sniff your duct" thread and realized there is a lithium battery issue here. Odor is definetly coming from THAT vent. But what I haven't found is anyone who said how they/toyota solved the problem and were they charged! There must be a few thousand of them out there. Can anyone help with this smell issue?
tech is offline
Old 10-13-2009, 10:22 PM   #2
Rokeby
Rokeby's Avatar
Default Re: My Prius has the STINCH!
tech,
to PRIUSchat.
Stinky air conditioning ducts, condenser, etc, is not an infrequent
complaint from owners in high temp, high humidity areas.
I don't know of an easy way to call up past threads on this subject.
However, if you use the search tool with "stinks" as the search term,
amongst the many threads listed, the threads discussing this issue are
easily identified.
Apparently, this can be a very difficult problem to fix. Good luck.
Hope this helps.
Rokeby is offline
Old 10-13-2009, 10:33 PM   #3
tech
THAT vent I'm refering to is the one at the right rear seatback going directly to the HV battery compartment. Odor emanates from there and once vehicle is closed up, it gets into fabrics/carpet. I have read back many threads and there are many complaints on this exact issue but I'm hoping for an answer before going to dealer. Other than that, I love the Prius!Thanks
tech is offline
Old 10-14-2009, 09:32 AM   #4
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
BTW, the traction battery is not lithium, it is NiMH.
I have not seen complaints of a smell coming from the battery vent before. I wonder if you have a dead rat in the ventilation ducting.
Patrick Wong is offline
Old 10-14-2009, 06:45 PM   #5
tech
Type in "smell" under search tab... and you're right about the batttery - NiMH, it's also HV - High Voltage - 500vdc! carefull when handling!
________________
2000 Honda Accord coupe
2003 Chevy TBlazer LT
2006 Lexus IS250
2008 Honda Civic LX coupe
tech is offline
Old 10-14-2009, 08:22 PM   #6
direstraits71
direstraits71's Avatar
Actually "only about 220 VDC" but still plenty dangerous!
direstraits71 is online now
Old 10-15-2009, 06:03 PM   #7
kkayser
Smells like a dead animal. Eventually it will dehydrate and stop smelling, but finding and removing is much faster. Try an ozone generator. It would not hurt to talk to the dealer.
kkayser is offline
prius battery stinch, prius odor, prius stinch
