This is a discussion on 2007 prius Oil change Instruction within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Anybody has 2007 prius oil change instruction?...
LinkBack (1) Thread Tools
Old 10-31-2009, 04:53 PM   1 links from elsewhere to this Post. Click to view. #1
duh_prius
Model: V
Package: #5 Touring
Default 2007 prius Oil change Instruction
duh_prius is offline
Old 10-31-2009, 06:14 PM   #2
Patrick Wong
DIY Enthusiast
Patrick Wong's Avatar
Friends: 44
Default Re: 2007 prius Oil change Instruction
john1701a has been a great source for basic info. However I noticed that his oil change instructions are updated for the 2010 model year. Therefore I've provided a page out of the repair manual; this is correct for Classic and 2G models.
Note the fluid capacities cited in the repair manual page. If you adhere to those guidelines you will likely find that your crankcase is overfilled based upon the engine oil dipstick.
I suggest that you add 3.7 US qt and then see where the dipstick level is after waiting a few minutes. The oil level should not be higher than the top dimple in the dipstick.
2006 Highlander Hybrid 4WD-i
2000 Ford Mustang GT conv.
Patrick Wong is offline
Old 11-02-2009, 08:00 AM   #3
Bob64
Sapphire of the Blue Sky
Bob64's Avatar
Here's a fool proof method to adding oil: Just add exactly 3 quarts. You'll end up right between min and max.
No pouring a bit in, rechecking the dipstick, and then adding a bit more. (also no worries about overfilling and having to drain/refill).
Bob64 is online now
Old 11-02-2009, 08:46 AM   #4
Patrick Wong
DIY Enthusiast
Friends: 44
Originally Posted by Bob64 View Post
...Just add exactly 3 quarts. You'll end up right between min and max...
That is reasonable.
My personal practice is to use 3.5 qt because I can save the remaining 0.5 qt for use at the next oil change without having to measure again. That refill amount brings the oil level to around 1/4" below the top dimple.
Why doesn't anyone advocate use of just enough engine oil to reach the bottom dimple on the dipstick? That would be a little more than 2 quarts...
This would be a bad idea because your engine would have no safety margin in the event of a leak or if it is worn to the point where it is starting to burn oil. Also, 2 quarts of oil would have to work twice as hard as the rated 3.9 quarts so you'd expect used oil testing to show greater degradation after a given number of miles had elapsed...
The Following User Says Thank You to Patrick Wong For This Useful Post:
Son of Gloin (11-04-2009)
Old 11-04-2009, 01:23 PM   #5
Son of Gloin
Son of Gloin's Avatar
( With thanks to Patrick Wong just above .... )
Using 3.5 quarts each oil change sounds good to me! I think that's what I'll ask for from now on ... beginning with Mithril's next oil change due the first week in December.
A few days ago, I took "him" in for a windshield treatment ( Aquapel ) and asked them to drain 1/4 of a quart while I was there as the oil level was a lot closer to the full indicator than the fill indicator.
It's way too early to tell if Mithril's MPG might consistently be a bit higher than it has been overall, but many here have reported fairly significant MPG improvement if the oil level is maintained toward the bottom of the range.
All I know for sure is that on the way to the dealership -- primarily south of here / driving into a very light, southerly wind -- the MFD indicated about 51.9 mpg for the 60 mile trip, and for the return trip the MFD indicated about 60.4 mpg.
I'm sure MUCH of that increase was due to the shift in relative wind ... but a 16.5% increase?!? That was WAY more than I'd expected!
my wife is still in love with "Stone White" ... our 1997 Stratus; but i prefer driving "Mithril" ... our 2008 / CSM / Pkg #3 Prius ....
Son of Gloin is offline
Old 11-04-2009, 03:02 PM   #6
Shawn Clark
Shawn Clark's Avatar
One of the reasons to use only 3 quarts under warranty is that the oil change interval is too short to begin with. The extra oil of 3.5 or 3.7 is simply wasted. If I extend the interval I might go back to 3.5 quarts, but not more. I like what my mileage has done as I've gone down to 3 quarts...may just be coincidental with break-in periods for car and driver(s).
Shawn Clark is online now
2007, change, instruction, oil, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-ii-prius-technical-discussion/71436-2007-prius-oil-change-instruction.html
How To Change Oil On 2007 Prius - Kosmix : Reference, Videos, Images, News, Shopping and more... This thread Refback Yesterday 01:29 PM
2010 instruction video's MFD Flying White Dutchman Gen III 2010 Prius Main Forum 3 05-09-2009 09:51 AM
Request for Lockpick3 instruction. yitsang Gen II Prius Audio and Electronics 0 06-09-2007 03:37 PM
2007 prius change lkhensley Gen II Prius Main Forum 3 08-17-2006 05:51 PM
Instruction to fix band expander in MK1 Prius (Jap Import) hdrygas Gen II Prius Main Forum 10 09-02-2004 09:25 PM
[ KB ] Instruction to fix band expander in MK1 Prius (Jap Im Danny Knowledge Base Articles Discussion 0 08-17-2004 08:25 AM
