This is a discussion on 2004 pruis at a stop engine keeps trying to start within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; Sitting In My Car With Engine On. Running on battery 1/2 charged waiting for my mom with the heater on. ...
Old 11-03-2009, 12:26 AM   #1
Jmack111
Angry 2004 pruis at a stop engine keeps trying to start
Sitting In My Car With Engine On. Running on battery 1/2 charged waiting for my mom with the heater on. Turn out the heater all the way to max so the engine comes on. To charge the battery. It sounded bad like to starting over and over for 10 sec. then I turned down the heat and back up worked fine.
It done some thing like this at lights too. Running ruff then other time it fine
Have new plug and battery, air filter and ran cleaner throw gas….
Jmack111 is offline
Old 11-03-2009, 09:12 AM   #2
jdenenberg
jdenenberg's Avatar
Default Re: 2004 pruis at a stop engine keeps trying to start
1. Check if the throttle body needs cleaning.
2. It's a pain, but replace the PCV valve.
3. You may have an intermittent plug igniter (separate coil per plug) or loose ignition wiring.
Good luck, JeffD
jdenenberg is offline
Old 11-03-2009, 05:39 PM   #3
nthach
If the 3rd scenario was true, you will also see the CEL light up and possibly the word Problem and a warning icon pop up on the MFD indicating a P030x DTC is triggered, which means a misfire has occured.
nthach is offline
Old 11-07-2009, 01:40 PM   #4
richard schumacher
Destination: Eschaton
By The Way, you don't have to do anything to manage battery charge. With the car on ("Ready") and in Park the engine will start automatically when it needs charging. If you make the engine start by turning up the cabin heat when you don't really want cabin heat, you're just wasting gas.
richard schumacher is offline
Old 11-09-2009, 12:40 PM   #5
triumph1
triumph1's Avatar
Mine did this once, last January. Hasn't done it since.
triumph1 is offline
2004, engine, pruis, start, stop
diagnosis for P3191 (engine does not start) and P3101 (engine system malfunction) wayne w International Owners 10 08-11-2009 08:38 PM
2010 Pruis 1.8 Engine ROCKS!!!!!!!! gofast Gen III 2010 Prius Main Forum 11 06-07-2009 03:30 PM
The Start/Stop button WWJD08 Knowledge Base Articles Discussion 6 09-07-2008 08:18 AM
"Engine Start Stop" vs. "Power" Buttons paulisme Gen II Prius Main Forum 2 04-21-2004 08:04 PM
Start, stop, start, stop ICE HTMLSpinnr Gen II Prius Main Forum 6 01-28-2004 11:08 PM
