This is a discussion on Transmission Question. Is the the ICE still coupled to the planetry gear when ICE is off? within the Gen II Prius Technical Discussion forums, part of the Gen II (2004-2009) Toyota Prius Forums category; If you think about designing the control algorithms for the HSD , there aren't many circumstances where a Prius runs ...
Old 11-08-2009, 10:50 AM   #11
Default Re: Transmission Question. Is the the ICE still coupled to the planetry gear when ICE is off?
If you think about designing the control algorithms for the HSD, there aren't many circumstances where a Prius runs all electric at speed, certainly not for any distance. I suspect the MG1 speed limit was set low to be conservative, knowing that it doesn't make a lot of practical difference whether it is 6500 RPM or 10000 RPM. Hypermilers and Prius nuts would like any extra they could get, but for an ordinary driver it is splitting hairs.
coupled, gear, ice, planetry, question, transmission
B Gear Question Cassandra Gen III 2010 Prius Technical Discussion 13 08-24-2009 12:41 PM
Question about the Prius transmission PaulHS Gen II Prius Main Forum 36 01-11-2009 02:01 PM
Planetary gear vs. CVT transmission jamarimutt Gen II Prius Main Forum 16 08-02-2007 06:38 PM
Out of gear tfelder Gen II Prius Care, Maintenance and Troubleshooting 7 07-19-2006 08:31 PM
The [B] gear?? senectus Gen II Prius Main Forum 29 03-01-2005 08:24 PM
