This is a discussion on Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by donkitchen Can you explain how to get to the parking lights and fog lights? I looked at ...
LinkBack (5) Thread Tools
Old 10-16-2009, 12:18 PM   #111
Paradox
Prius Enthusiast
Paradox's Avatar
Model: V
Package: Adv. Technology
Friends: 9
Default Re: Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs
Originally Posted by donkitchen View Post
Can you explain how to get to the parking lights and fog lights? I looked at replacing the parking lights and didn't see how you can easily access the bulb. Please don't tell me the whole headlight housing needs to be removed.
Also, I'm guessing the fogs will require the inner fender well trim to be removed. Is that correct?
Originally Posted by Paradox View Post
The parking lights are rather easy, it was the fog lamps that while not hard just took a bit more time.
The drivers side parking light is easy, just grab hold and twist on the connector. I wore a pair of those gardening gloves with the silicon dimples on them for a bit extra grip, plus so I didn't touch the old bulb with my bare hands and get oil on it.
The passenger side, you need to take off the one bolt that connects to the clamp which holds onto the black hose right behind the headlamp housing. Then lift up a bit on the hose and move it out of the way. reach on in and twist... I've got big hands and got it so keep trying, they'll eventually loosen up for ya' and 'untwist'.
The above post from post # 1010 in this forum should explain the parking lights. Just pm me if you have trouble. If people would like pictures taken of how to replace the parking lights and the fog lights let me know I'll try and get pics up later in the day (I'll have to go take them first)
The fog lights I did the day I got the car but I think it just involved taking off a clip (one of those round ones that kind of act like a turkey pop up timer) and a screw with a hex head from a black panel directly under the car in each corner of the front bumper. The fun part is once they are off (well not off, I just pulled the front of the panel down and stuck my hand inside there) you cannot really see inside there easily so everything your doing you do my feel.
Mark - Priuschat Moderator & Prius Expert
"Facebook - Ask An Expert"
I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota.
Last edited by Paradox; 10-16-2009 at 12:42 PM. Reason: Deleted double quote of myself, oops.
Paradox is online now
Old 10-16-2009, 12:20 PM   #112
donkitchen
Model: V
Package: Navigation
Thanks. I'll give it a shot. And while I can probably manage without the pictures, I'm sure folks would appreciate the visual aid moving forward.
donkitchen is offline
Old 10-16-2009, 03:10 PM   #113
stream
stream's Avatar
Model: V
Package: Navigation
As I've stated--several times in this thread --the owner's manual contains bulb replacement instructions.
stream is offline
The Following User Says Thank You to stream For This Useful Post:
donkitchen (10-16-2009)
Old 10-16-2009, 03:13 PM   #114
donkitchen
Model: V
Package: Navigation
Sorry, the thread got kind of long and I guess I was being lazy. Thanks again for pointing this out. Has all the info I need
Old 10-16-2009, 06:17 PM   #115
Paradox
Prius Enthusiast
Paradox's Avatar
Model: V
Friends: 9
Well call me dumb I guess. I figured you had just looked at it already and still had some questions...
The manual was what I went to to get a basic idea of how to replace them all...
Old 11-07-2009, 05:53 AM   #116
krouebi
krouebi's Avatar
Package: Solar Premium
Thumbs up Re: Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs
Hi,
A very good and informative thread - thanks a lot!
However, while replacing the low-beam halogens on the models with conventional headlights with Xenon retrofit units might be questionable, replacing the high beam bulbs should not really be an issue, as anyhow high beams are not to be used when any other traffic is in sight.
I have the version with LED low-beams (which are absolutely excellent), but the reach and particularly the color difference when you turn on the conventional HB3 high-beams is really .
Fortunately I still had a set of Chinese-made HB3 Xenon retrofits from my former Lexus RX400h (which also suffered from this design flaw), and putting them in the Prius was really easy. As most of these kits, the hardware is technically OK (the "hotspot" on the Xenon burner corresponds exactly to the placement of the filament in the HB3 bulb), the wiring and connections are of a good quality, and connections are really "plug & play".
The result is absolutely convincing: The high beams (4300 K) much more closely match the color of the LED's, and the high beam itself is REALLY far and wide reaching, very uniform - no streaks or black spots anywhere.
I drive a lot in dark conditions - and on stretches of road where I can keep the high beams on for long distances. I would not be able to this kind of driving safely with the stock bulbs - with the Xenons a 400-mile drive through the night is kid's play .
Fitting is easy - and the ballasts have found their places: Passenger side over the expansion tank of the coolant system (fitted to existing bolts), driver's side fitted to the fuse box cover (fitted with short bolts & nuts, not protruding on the inside of the cover and additionally isolated).
Kind greetings from Krouebi, living in one of Europe's smallest countries, nonetheless featuring the four biggest gas stations worldwide Click the image to open in full size.- the GranBenzinato de Luxyland.
krouebi is offline
Old 11-13-2009, 01:06 PM   #117
spiderman
Prius I am
spiderman's Avatar
Model: II
Hi all,
I went throught he entire thread and I did not see where anyone had replaced their turn signals with LEDs? Please forgive me if that was covered. If anyone has and didn't post their results, please do.
Thanks,
Peter
spiderman is offline
Old 11-13-2009, 01:10 PM   #118
krouebi
krouebi's Avatar
Hello Spiderman,
Have a look here: Interior LED Lighting?. The turn signals are also treated there.
krouebi is offline
Old 11-13-2009, 02:51 PM   #119
spiderman
Prius I am
spiderman's Avatar
Model: II
Originally Posted by krouebi View Post
Hello Spiderman,
Thanks, wouldn't have thought to look there!
Old 11-14-2009, 02:05 AM   #120
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
Someone in Japan switched his fogs and indicators to LEDs but I never got a reply from him/her. Probably doesn't know English...
Tideland Prius is offline
beams, bulbs, fog, high, license, lights, parking, plate, rear, replaced, signals, turn
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/63356-replaced-turn-signals-fog-lights-high-beams-parking-lights-rear-license-plate-bulbs.html
Mi Toyota Prius - Fotos de cambio de bombillas por leds en los Prius USA - Tuning Prius 3G This thread Refback 11-14-2009 05:38 PM
Mi Toyota Prius - Fotos de cambio de bombillas por leds en los Prius USA - Tuning Prius 3G This thread Refback 10-20-2009 02:52 PM
Mi Toyota Prius - Fotos de cambio de bombillas por leds en los Prius USA - Tuning Prius 3G This thread Refback 10-04-2009 11:48 AM
Toyota Club Denmark: Forums / Sælges / Blinkpære - Philips WY21W This thread Refback 09-29-2009 06:14 AM
RAV4World - :: View topic - Turn Signal Modification? This thread Refback 09-03-2009 05:17 PM
Tail and license plate lights went out -- brake lights work dialwmd Gen II Prius Care, Maintenance and Troubleshooting 14 06-29-2009 07:44 PM
Mod to turn fog lights on with parking lights? exbauer Gen III 2010 Prius Main Forum 1 06-08-2009 05:43 AM
How to disable the High Beams turning off the fog lights jelster Gen II Prius Modifications 22 02-05-2009 12:30 AM
Need side turn signals, rear fog light AND clear front parking light cover MelisPrius Gen II Prius Modifications 2 08-13-2008 08:37 PM
"Improved" fog lights, ONLY with high beams? fphinney Gen II Prius Modifications 0 08-01-2006 01:10 AM
