| This is a discussion on Replaced Turn Signals, Fog Lights, High Beams, Parking Lights & Rear License Plate Bulbs within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; LED Fogs would be pretty slick. Like to see that info if you come across it. Originally Posted by Tideland ... |
| | LinkBack (7) | Thread Tools |
| | #121 |
| Member Join Date: Aug 2009 Location: Mt Airy, MD
My Car: 2010 Prius Model: V Package: Navigation Thanks: 4
Friends: 0 | |
| | #122 | |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 25
Friends: 11 | Quote:
I found LED bulbs for our fog lamps many months ago and posted about them. I dont have the link sorry. But my concerns are evident in this post in this forum: LED H11 Fog Light Bulbs... - Drive Accord Honda Forums The LED's in the fog lamps are simply not bright enough. They are for looks more than anything. The ones I found were $25 a bulb and consisted of one either 1W or 3W luxeon LED. They would look reallyh sweet against the LED's on a Prius V and the LED parking light conversion some of us have done, but in the way or practical lighting they just wouldn't do much.
__________________ Mark - Priuschat Moderator & Prius Expert ![]() "Facebook - Ask An Expert" I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota. | |
| | #123 | |
| Junior Member Join Date: Sep 2009 Location: new jersey
Rick, I've recently purchased a 2010 Prius IV. I've been following the posts regarding people swapping stock bulbs with whiter and brighter one's. Since I'm no expert I just want to be sure that it's safe to replace the stock bulbs as follows: front and rear turn signals with Phillips Silver Vision, parking lights and rear license plate with Phillips Blue Vision and the high beams with PIAA Intense White. Thanks. | |
| | #124 | |
Is it to DOT code, probably not since the silver stars and blue visions are not sold in the US, but they will not cause any problems. Myself and others have been using them on our 2010's since May/June as well as used them on previous vehicles for years without any problems. | |
| | #125 |
My Car: 2010 Prius Model: N/A Package: Technology Package (Canada) Thanks: 370
Friends: 26 | Blue vision isn't that much brighter so I'm sure it's DOT compliant (I have the blue visions as my maplights and the stock lamp as the personal light and there's a difference but not as much as you think). Silverstars aren't that much brighter either lol. THey're just whiter, giving an illusion that it's a lot brighter than it really is. This is the standard Sylvania Silverstar (not the Silverstar Ultra or the Osram Silverstar). |
| | #126 | |
Yeah, the blue visions do give off a brighter whiter light compared to stock when used inside the car like in the map lights and doors but once its done it's not a wow look at that change like LED's would be. The fact the bulb is blue, if used on external applications, may make it illegal but not sure since it can only be used for parking lights etc not headlights. For the silver stars, I was thinking he meant the silver ones me and stream did with the silver coating on them so you don't see the yellow in the reflector. But I already forget the name of them, silver something right? lol, too late last night and too early this morning | |
| | #127 | |
| Senior Member Join Date: May 2008 Location: SF Bay Area
My Car: 2010 Prius Model: V Package: Navigation Thanks: 63
Friends: 2 | Quote:
If you look at the first post of this thread, the bulbs you list above are the ones I used to upgrade my Prius (plus I upgraded the fogs). That was 6 months ago and no issues. I've also used these bulbs on several other cars, with no issues. I had them in my last car for 4.5 years with no issues. All these bulbs are from high quality manufacturers. Where you could run into trouble is with some off brand bulb that draws more wattage than the stock bulbs (which is the cheaper alternative to achieving whiter/brighter light), and then you could have an electrical issue, or heat issue (that could melt the housings or lenses). | |
| | #128 |
| Member Join Date: Aug 2007
My Car: 2010 Prius Model: V Package: Navigation Thanks: 7
Friends: 0 | I just completed the next round of LED conversion. This time it was the map lights. The images below show the various parts I cobbled together including a couple of incredibly bright Cree XPG R5 bin LED's (from cutter), a pair of inexpensive constant current drivers (from Sure Electronics), and a couple wedge base adapters stolen from some other LED replacement "bulbs". One of the pictures below shows them only partially installed (I still need to pick up some thick double sticky foam for the driver board) but it's close enough to get an idea of the size of the components. The end result is amazingly white and bright with a broad uniform spread. The camera doesn't show how different the color temperature actually is. In reality the stock bulbs look like dim orange candlelight in comparison. I was wondering if the single XPG's would end up being bright enough and had contemplated using a 3way light engine on each side. After seeing these installed, I'm glad I didn't. These ended up on the high end of how bright I would want them. Much brighter and I think they might cause sunburn. I'm pretty floored by how much light these little guys put out without even driving them very hard. I'm driving them at only 700ma but they are rated at 345 lumens at 1A. (Heck with those millicandela specs, these things rate like regular light bulbs!) Now to do a similar install for the dome and cargo areas. ![]() ![]() ![]() ![]() ![]()
__________________ -Jim 2010 BP V/Nav, Pinnacle 35, LED sill plates , LED interior and exterior bulbs, Full ClearMask plus mirrors, sills, and door cups, Carbon Fund plates w 100% offset, Lifetime XM Last edited by jsharpe; 11-28-2009 at 08:46 AM. |
| | #129 |
| Noob Join Date: Jul 2009 Location: Fairmont, WV
My Car: 2010 Prius Model: III Package: Navigation Thanks: 55
Friends: 0 | I like it. The map lights are a bit dim. So, when you ordered our LED's from cutter, did you order it mounted to the XPG10SRO base (I'm guessing from the part #, it's a 10mm round base)? |
| | #130 | |
I'm still amazed at the massive amount of light that comes out of such a small single dot. You definitely won't think these are too dim. They do run a bit warm but that would be easy to fix with a small heat sink. I didn't bother since they typically aren't on very long. For the dome and cargo lights a bayonet adapter would be useful, although I ended up just tucking the power leads between the metal parts and the plastic frame. The spring pressure was plenty to hold them securely. Last edited by jsharpe; 12-01-2009 at 05:34 PM. | |
| beams, bulbs, fog, high, license, lights, parking, plate, rear, replaced, signals, turn |
| Tail and license plate lights went out -- brake lights work | dialwmd | Gen II Prius Care, Maintenance and Troubleshooting | 17 | 01-13-2010 12:46 PM |
| Mod to turn fog lights on with parking lights? | exbauer | Gen III 2010 Prius Main Forum | 1 | 06-08-2009 05:43 AM |
| How to disable the High Beams turning off the fog lights | jelster | Gen II Prius Modifications | 22 | 02-05-2009 12:30 AM |
| Need side turn signals, rear fog light AND clear front parking light cover | MelisPrius | Gen II Prius Modifications | 2 | 08-13-2008 08:37 PM |
| "Improved" fog lights, ONLY with high beams? | fphinney | Gen II Prius Modifications | 0 | 08-01-2006 01:10 AM |
