This is a discussion on New Alloy Wheels on the 2010? within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; I have been a long time lurker and this is my first post. My wife owns a 2007 Prius and ...
Old 06-22-2009, 03:37 PM   #1
millerjl26
Default New Alloy Wheels on the 2010?
I have been a long time lurker and this is my first post. My wife owns a 2007 Prius and I am expecting the 2010 Winter Grey IV in early July. I really like what has been done to the exterior of the 2010 with one exception - the alloy wheels and the plastic wheel covers. I would be willing to spend the money to replace these but as someone who has never purchased non-oem wheels I am not sure what issues I should be concerned about. I would expect there may be a change in wind resistance, and perhaps more of the guts (brakes, etc) would be exposed with wheels with a different spoke configuration. Are there other things I should be concerned about? Any comments on my listed concerns? Anyone have any suggestions one what would look and perform well on the stock 15 inch tires?
millerjl26 is offline
Old 06-22-2009, 03:47 PM   #2
The Electric Me
Go Speed Go!
The Electric Me's Avatar
Default Re: New Alloy Wheels on the 2010?
You might search around the forum if you haven't already seen this. But some have removed the wheel covers and bought caps for the alloys.
How it looks is subjective. Those that have done it, like it, but reaction has been mixed. I think it looks fine. Might be a wind resistance change, but at least your running on the Toyota provide rims. I can't imagine it would make too huge a difference.
I might be in the very, very rare category of those that actually think the wheel covers don't look that bad.
The Electric Me is offline
Old 06-23-2009, 12:24 AM   #3
Tideland Prius
Moderator of the North
Tideland Prius's Avatar
Friends: 23
If you're going aftermarket, here are a few things you need to arm yourself with:
- get the specs of the tyre (so 195/65R15). Make sure the new rim can mount those tyres
- make sure the bolt pattern is the same (I don't have that info)
- Note that they will be heavier than stock (the 15s are lightweight alloys)
Tideland Prius is offline
Old 07-03-2009, 08:16 PM   #4
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
Check post 2 of this thread for wheel size and offset:
Wheel weight
In addition to the 15 and 17 inch sizes you could also consider 16 inch wheels with 205/55 tires. Here is a good site to start looking for wheels or wheels and tires. If you call or email them they will answer your questions. I have had pretty good luck with them over the years.
Tire Rack - Your performance experts for tires and wheels
Don't forget about the TPMS sensors, if you don't use the same ones you need to have the new ones programed by a dealer.
tumbleweed is offline
Old 07-04-2009, 10:57 AM   #5
accordingly
Just a couple clarifications- you can use the same tires if you want, but then you will be restricted to the 15" size wheel. If you decide to get larger wheels, you'll have to get a lower profile tire in order to match the same outside diameter as the OEM setup.
Also, the stock 15" wheels aren't that lightweight at 16.3 pounds (7.4kg). You can easily find replacements that weigh the same or even a pound or so less at a very reasonable price. You could step up to 16" or 17" wheels without too much compromise in weight (or even stay the same) and not break the bank. The stock 17" wheels from the Prius V are very heavy for 17" at 24 lbs (11kg) and you can easily stay under that on bargain 17" wheels.
accordingly is offline
Old 07-04-2009, 08:35 PM   #6
Tideland Prius
Friends: 23
Yup. I thought he was sticking with 15".
Hmm... so they went up in weight? The Gen 2s are 14 lbs.
Old 09-06-2009, 12:48 PM   #7
chuck favano jr
Model: II
Package: Navigation
where can u get the center toyota insert for the rims
chuck favano jr is offline
Old 09-06-2009, 01:02 PM   #8
rachaelseven
rachaelseven's Avatar
15" wheel center caps
rachaelseven is offline
Old 09-06-2009, 04:47 PM   #9
FreakinToddles
How do you keep the spedometer accurate after you buy larger wheels?
FreakinToddles is offline
Old 09-06-2009, 06:03 PM   #10
Tideland Prius
Friends: 23
look for a tire size calculator. That'll help you determine the exact specs if you want to increase the size of your wheel.
2010, alloy, wheels
FE with Steel v. Alloy Wheels? rpg51 Gen II Prius Fuel Economy 17 10-01-2009 09:10 PM
WTB 4 - 2008 Prius 15" oem alloy wheels earthman Private Sales 3 09-01-2009 04:07 PM
17" alloy wheels and tires for 2010 halvormark AZ - Phoenix 7 06-04-2009 08:04 PM
Rotate Tires with Alloy Wheels rpg51 Gen II Prius Care, Maintenance and Troubleshooting 9 10-24-2008 03:30 AM
Prius 2005 Alloy Wheels, a full set Dianne Private Sales 0 01-19-2006 07:14 PM
