Thule vs. Yakima Roof Rack for 2010 Prius
| | #61 | |
| Senior Member Join Date: Dec 2009 Location: chicago
My Car: 2010 Prius Model: III Package: Base Thanks: 23
I did notice some of the clearcoat being ... roughened up a bit, although its very slight. It looks like it can be buffed out since its very slight & can't be seen easily, esp. on my white car. Here's the image below, if you look, you can see a slight squarish part of the paint where the Thule rubber feet used to sit on: ![]() So, hope that helps for anyone installing a temporary rack on their car, just be aware of the paint being slightly scuffed. You could probably put polyurethane tape under the rubber feet/pads to totally avoid this - I tried that initially but didn't like the look, so this is what turned out. | |
| | #62 | |
| Junior Member Join Date: Feb 2011 Location: California
My Car: 2007 Prius Model: N/A Package: N/A Thanks: 1
That happened w/ my 2001 prius (scratched up because of friction) and now I have a newer version Prius; so I'm investigating if it's worth it to have permanent rail system installed. I called Rack n Road and they said it would be about $100 just for the install. I figure that $100 for install is cheaper than getting the side rails painted to avoid rust. | |
| | #63 |
| Member Join Date: Jan 2008 Location: Playa Vista
Friends: 0 | Would polyurethane tape help to avoid this as previous poster stated? I am really considering the roof rack for my road bike.. but i dont like the Clamp system nor the rubber feet compressing against the roof paint. Why couldnt toyota just make a rack mounting system as an option... just like BMW, if you dont want it, cover it with a rubber/plastic mold. If you want it, uncover it and screw on the feet for the rack. sigh.... |
| | #64 |
| 2006 Insight-I MT + 2011 Prius Join Date: Aug 2009 Location: Essex, CT
My Car: 2011 Prius Model: Two Package: N/A Thanks: 34
Friends: 0 | I had Yakima tracks permanently fastened to the roof of my 2011 at a place called Rack Attack. The cross bars are very easy to clip on and off. When they're off, there's very little drag because the tracks run parallel to the car. I can get >43" spread between the bars, which is great for stability. The bare bars make noise, but I don't want to use a spoiler because it gets in the way of my load system. When I have a load on there it breaks up the flow so there's no noise, so I just remove the bars (they fit inside the car if I need to bring them along) when I have no load. Of course if you have a solar roof this probably won't work. |
| | #65 |
| Senior Member Join Date: May 2011 Location: West Palm
My Car: 2011 Prius Model: Three Package: Solar Roof Thanks: 99
Friends: 0 | After seeing all the fuel consumption with the top mount roof racks I may just get the rear one now. But dang I love me a roof rack lol |
| | #66 | |
| | #67 |
| Senior Member Join Date: May 2007 Location: Endwell, NY
My Car: 2011 Prius Model: Three Package: #3 Thanks: 2
Friends: 0 | Long time lover of Thule rack systems. Better car balance with a roof rack. Load is between the axles. Aero feet are on so tight you could tow the car with the bars. I have Thule parts from 30yrs ago that work great today. |
| 2010, prius, rack, roof, thule, yakima |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/63980-thule-vs-yakima-roof-rack-2010-prius.html | ||||
| barre thule per prius con solar roof | This thread | Refback | 08-09-2011 09:25 AM | |
| barre thule per prius con solar roof | This thread | Refback | 07-13-2011 04:27 PM | |
| Hobie Mirage Sport and 2010 Prius | This thread | Refback | 05-30-2011 08:40 PM | |
| Skiing Boots | This thread | Trackback | 02-03-2011 05:38 AM | |
| Hobie Mirage Sport and 2010 Prius | This thread | Refback | 07-08-2010 03:47 AM | |
| Hobie Mirage Sport and 2010 Prius | This thread | Refback | 07-08-2010 02:54 AM | |
| Hobie Mirage Sport and 2010 Prius | This thread | Refback | 07-04-2010 07:02 PM | |
| barre thule per prius con solar roof | This thread | Refback | 05-21-2010 02:57 AM | |
| Yakima Roof Rack | diatomguru | Gen II Prius Modifications | 15 | 05-27-2009 05:56 PM |
| Thule Roof Rack Tracks | McDonald | Gen II Prius Modifications | 18 | 10-01-2008 01:06 AM |
| yakima roof rack | findlj | Gen II Prius Main Forum | 2 | 08-21-2006 10:33 AM |
| Thule roof rack | malcolm | Private Sales | 2 | 06-27-2005 07:03 PM |
| Yakima Roof Rack | marinjim | Gen II Prius Modifications | 5 | 04-05-2004 11:08 AM |
