2010 Prius EV mode Hack
| Junior Member Join Date: Jul 2009 Location: CA
My Car: 2010 Prius Model: II Package: No Package Thanks: 5
Friends: 0 | I'm wondering if anyone out there know anything about the 2010 Prius EV Mode hack. I'm making great use with the factory EV, but I'm limited to 25mph. I'd like to know how to bypass it and get a higher mph, like the pre-2010 that actually goes up to 34mph. Help..... anyone? thx in advance |
| Thanked by: | dave77 (10-28-2009) |
| Senior Member Join Date: May 2009 Location: Eastern PA
Friends: 0 | Mine kicks out of EV at 13mph almost every time. Why? |
| Member Join Date: Oct 2005 Location: Boulder, Colorado
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 0
Friends: 0 | Mine kicks out of EV mode at all different speeds depending on the variables used in the software that determines when to terminate EV mode. I can get up to 25mph in EV mode at times. It would be great if someone that knew these variables would post them. |
My Car: 2004 Prius Model: Package: #9 Thanks: 215
Friends: 47 | I suspect that'll take a serious firmware hack to accomplish that is likely far beyond your programming skills and available equipment to accomplish. |
Friends: 0 | |
My Car: 2012 Prius Plug-in Model: Plug-in Advanced Package: No Package Thanks: 137
Friends: 22 | What is it with the "EV mode" obsession? There is a lot of confusion when it comes to the electric-only driving. STEALTH is still available at speeds up to 45 MPH. The engine isn't moving (0 RPM if you have an aftermarket gauge available) and you can clearly see the resulting 100 MPG on the new meter by the speedo. . |
| Senior Member Join Date: Jun 2009 Location: Washington DC
My Car: 2010 Prius Model: III Package: No Package Thanks: 9
Not to mention that an over-obsession with operating under battery power only will mess up your mileage. (For that matter, over-obsession with instantaneous MPG and the HDI displays will do the same thing. As I've taken a big-picture view of things, my mileage has gone up. The last tank is, so far, 10% better than the previous tank.) | |
Understand about the "Stealth", minimal pedal depression, w/electric motor assist. In traffic stop n go, it's nice to be able to go beyond 25mph. Ford Fusion is up to 47mph, with very very light pedal pressure. | |
Can someone explain how using electric motor only can negatively impact gas mileage? I'm thinking the more I'm able to use electric only, the less gas I use. | |
| Junior Member Join Date: Jun 2009 Location: CA
Friends: 0 | Try using EV + Power Mode together. I find that when I use EV + ECO mode, the accelleration is so slow I end up having to hit the gas so hard, that the ICE starts up. With EV + Power mode, I can accellerate 'briskly' with electric only, and if I let up on the gas when hitting 24 MPH, it will sometimes go up to 26-28 MPH, still in EV mode. Once the engine kicks in, I switch to Eco mode. I'm totally new to the Prius, so thake that into consideration. I purchased my 2010 (IV, w/ NAV, white, dk leather) about 5 weeks ago. Commuting to work 10 miles each way, stop/go traffic, I'm getting about 53 MPG. As for avoiding EV mode (as per a HyperMiler article that I read), it doesn't really work for me. I live about 1 mile from the freeway onramp, and I can sometimes get there in EV mode (engine warmup takes about 2 blocks). The freeway run charges up the battery, until I hit stop/go traffic, and then it's back to EV mode for a while. I'm very happy with the Prius so far, and I'm leaving tomorrow for a 2500 mile trip from SoCal to Idaho & Montana. I'll share my results when I return. --- |
| hack above 25mph ev mode |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/64614-2010-prius-electric-vehicle-mode-hack.html | ||||
| Prius Hack at Askives | This thread | Refback | 03-15-2012 01:07 PM | |
| Thread 2010 Prius EV mode Hack | PriusChat Forums | BoardReader | This thread | Refback | 07-19-2011 08:23 PM | |
| EV Modus erhöhen - PRIUSforum | This thread | Refback | 06-08-2011 06:15 PM | |
| EV Modus erhöhen - PRIUSforum | This thread | Refback | 08-13-2010 06:00 AM | |
| DVD Nav 8.1 hack on 2009 prius? | kiettyyyy | Gen II Prius Main Forum | 37 | 01-19-2011 07:23 PM |
| 2010 Hack question | MrChristian | Gen III 2010+ Prius Technical Discussion | 38 | 06-10-2010 08:06 PM |
| 05 Prius Radio Hack? | bugssmith | Gen II Prius Audio and Electronics | 1 | 04-06-2008 03:32 AM |
| Prius Hack Installations | starkeef | Gen II Prius Audio and Electronics | 2 | 01-28-2007 01:41 PM |
| Hack your Mac into your Prius MFD!! | m2oore | Gen II Prius Main Forum | 1 | 03-22-2006 09:04 PM |
