| This is a discussion on Aftermarket / Portable GPS in Non-Nav Prius within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by RickFlashman I have my TomTom One (3rd Gen) installed in the same place! Works awsome and is ... |
| | #21 |
| Senior Member Join Date: Sep 2009 Location: Cowtown
My Car: 2010 Prius Model: IV Package: Base Thanks: 24
Friends: 0 | |
| | #22 |
| Junior Member Join Date: Sep 2009 Location: SF
My Car: 2010 Prius Model: II Package: No Package Thanks: 0
Friends: 0 | |
| | #23 |
Friends: 0 | OK. Where exactly did you run the wires in your 2010 Prius? To be more specific, did you remove any panels? Which ones and how did you remove them? Did you go under the car to get to the battery in the back, or did you route the wires some other way, like maybe to the fuse box? |
| | #24 |
| Member Join Date: Apr 2009 Location: Western NY & Leesburg Fl.
My Car: 2007 Prius Model: N/A Package: #3 Thanks: 2
Friends: 0 | Hi guys. I know this is the 2010 Prius forum, but I have a 2007 Prius, and I want to put my Garmin right on the drivers side little window just like this thread shows. At the risk of looking foolish, how did you do it? Is the 2010 little window less deep then my 2007? When I attempt to attach the garmin suction cup holder with the ball end to the window, the garmin will not go on it......like the arm is WAY too short. Is there a different arm I could buy, or an attachment to bring it out farther? That is the perfect spot, but how can I do it on my 2007? Thank you in advance for your help. Frank D. |
| aftermarket, gps, nuvi |
| Using a portable Garmin-type GPS in 2010 Prius? | web1b | Gen III 2010 Prius Audio and Electronics | 26 | 11-16-2009 06:27 PM |
| Do you use the Prius Nav or an Aftermarket GPS? | tom1l21 | Gen II Prius Audio and Electronics | 16 | 04-24-2009 11:32 PM |
| prius portable solar panel | djphill | Gen II Prius Modifications | 14 | 12-08-2008 02:13 PM |
| Jump You: Jumping a Non-Prius with a Portable Starter | a priori | Gen II Prius Main Forum | 32 | 07-27-2008 05:32 AM |
| portable xm radios okay/good for a prius? | knownasmichael | Gen II Prius Audio and Electronics | 17 | 02-25-2008 05:41 AM |
