| This is a discussion on High Performance Air Filter within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; At my first inspection of the engine air filter today, I found it to be made of paper. I was ... |
| Senior Member Join Date: May 2009 Location: Grants Pass, OR
My Car: 2010 Prius On Order Model: III Package: Navigation Thanks: 53
Friends: 1 | At my first inspection of the engine air filter today, I found it to be made of paper. I was hoping to find it made of cotton at least but it isn't. Looking online, I found no one makes a high performance replacement yet . When they do, I'll buy one. |
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 215
Friends: 18 | This car doesn't breathe that much in comparison to high performance cars. Unless you're running WOT, I doubt you'd see much difference. |
Friends: 1 | If it were cotton, I would not bother with it. Paper on the other hand can be very restrictive. K&N Air Filters can be cleaned and reused so they can last a very long time. I have always noticed a difference in performance with K&N Air Filters. |
| Senior Member Join Date: Jul 2009 Location: Jacksonville, FL
My Car: 2010 Prius Model: III Package: No Package Thanks: 37
Friends: 0 | Measure your air filter and see if the dimensions compare to the Gen II or another Toyota. You could be the first with a K&N on your Gen III. |
| Senior Member Join Date: Jun 2009 Location: the aloha state
My Car: 2010 Prius Model: III Package: Navigation Thanks: 8
Friends: 0 | I would like to purchase one eventually. I haven't checked yet, but normally you change out the air cleaner filter at 30k or 2 years. Amsoil has IMO a better air cleaner filter than K&N. Instead of cleaning, drying, and re-oiling the filter, you just use a vacuum to clean it. Much easier and re-usable like the K&N. Amsoil makes quality products. |
Friends: 35 | Quote:
From a money savings standpoint the K&N makes sense, especially if you are buying full price Toyota filters but from a performance standpoint with regards to the Prius I would wager $100 you cannot feel a HP difference between a quality filter and a K&N.
__________________ 2005 Prius - Upgrades: Kenwood eXcelon KDC-X993, Diamond Audio D9800.2 and D61500.1 (1900w RMS), Diamond Audio D971 7" component set, 2 Diamond Audio D910D4 10" subwoofers (600w/ea). ![]() California Rangeland ConservationCoalition Ranchers, Environmentalists, And Agencies Working Together For The Benefit Of All. | |
| The Following 3 Users Say Thank You to F8L For This Useful Post: |
My Car: 2007 Prius Model: Package: B Thanks: 3
Friends: 0 | Be aware there is some controversy re the effectiveness of K&N and other cloth filters. Some have tested them and found they pass fine dust, particularly in industrial applications. I've used them in the past (but so far not in Pearl) and didn't notice anything getting past but my tests wouldn't be hard to pass (paved road driving most of the time). While a little more restrictive, a paper filter does work very well. They just put more filter area in to keep the restriction under control. As already posted, Prius engine rarely runs at full RPM, usually cruising along below 2K RPM (by design). This requires very low volumes of air. Note also that the max. RPM the engine will see is also not high (5000 for the GII) so air volume requirements may not be that great.
| Senior Member Join Date: May 2008 Location: SF Bay Area
My Car: 2010 Prius Model: V Package: Navigation Thanks: 58
Friends: 2 | Quote:
Friends: 0 | I am going to buy a K&N for my Prius not because of the increase in power or mpg (because we all know it will be negligible) but because it can be reused. On my turbo Eclipse however, the K&N did help a lot but that is because I run twice the amount of air that a naturally aspirate engine does. Can someone confirm the size of the Gen III? |
| Management Scientist Join Date: Feb 2009 Location: Denver Metro
My Car: 2006 Prius Model: N/A Package: #2 Thanks: 88
Friends: 5 | Same here. However, I find I keep falling off the rollers. How do you manage to stay upright when you're running on those things? I bet one of those loggers who roll logs in the water would produce good numbers. At least they could stay on the roller. If you use a 4WD dyno, do you use your feet on one roller and your hands on the other? lI'd fall flat on my big belly if I tried that! Do performance shoes increase the dyno numbers? Which shoe do you find to provide the best traction on the rollers? Do you just attach the safety chains to your belt, or do you have a harness? Do you monitor RPM (Running-shoe-hits Per Minute) and speed to calculate HP (Human Power)? Do you calculate speed in feet per second? I only have 2 feet - more feet might be an advantage. Hmmm, now I'm hungry for a foot-long hot dog. I think I'll run off to lunch.
__________________ ![]() Bartlett leather, black Wheelskin, Infinity Reference speakers: 4 2-ways & 2 tweeters, 10" sub, Clarion 500W 5-channel amp, VAIStech SL2xmt XM, 30% tint, custom pinstripe/graphics. My pics. |
| air, filter, high, performance |
| For Sale Cabin Filter, Oil Filter, Engine Filter | moolman | Private Sales | 6 | 06-25-2008 08:23 PM |
| High Performance Building Perspective and Practice (video) | F8L | Environmental Discussion | 4 | 06-21-2008 05:54 PM |
| Performance at high altitude ... | dfrost7 | Gen II Prius Main Forum | 2 | 05-26-2007 12:15 PM |
| HIGH-PERFORMANCE ELECTRIC CAR GETS 200 MPG | Areometer | Other Cars | 17 | 04-27-2007 07:43 PM |
| Tesla to build high performance electric sedan | allargon | Other Cars | 9 | 02-23-2007 12:16 PM |
