This is a discussion on Wheelskins (Steering wheel cover) within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; I like the look of the factory wheel with the silver spokes exposed (not covered in leather) Is there anyway ...
LinkBack (1) Thread Tools
Old 08-24-2009, 06:54 PM   #41
kawita
Model: II
Default Re: Wheelskins (Steering wheel cover)
I like the look of the factory wheel with the silver spokes exposed (not covered in leather) Is there anyway you can get that look with aftermarket leather?
kawita is offline
Old 08-24-2009, 07:27 PM   #42
cpatch
cpatch's Avatar
Package: Navigation
You could always order a factory wheel from Sigma for $350!
After seeing that photo I've realized I don't want the Wheelskins look (and I can't afford $350 either). If anyone in the U.S. wants a plain black one (new in box) for $35 shipped Priority Mail PM me.
cpatch is offline
Old 08-26-2009, 07:36 PM   #43
kawita
Model: II
Anyone know if that would work with the airbags?
kawita is offline
Old 08-26-2009, 11:03 PM   #44
momo
Model: II
It should not affect the airbag because the airbag deport from the center of the steering wheel.
momo is offline
Old 09-09-2009, 05:00 PM   #45
hschen
hschen's Avatar
Model: II
I know many of you don't like the leather wheel wrap. I am one of those who can't drive without it. So attached is my poor man's leather steering wheel. My workmanship is bad, I know.
hschen is offline
Old 09-09-2009, 07:03 PM   #46
cpatch
cpatch's Avatar
Package: Navigation
I'm pretty sure it's a factory replacement for the existing wheel so it shouldn't be a problem.
cpatch is offline
Old 09-26-2009, 12:28 AM   #47
Boo
Boola Boola Member
Boo's Avatar
Friends: 22
I think yours looks fine. And your workmanship is fine too.
I think the Gen III steering wheel presents a fitment issue that the Gen II and many other cars do not have, namely the multi-faced vertical spokes on the bottom.
Given the Gen III steering wheel and the different Wheelskins I've seen on it, I'm convinced that the best Wheelskins for it has to be solid colored and smooth (non-perforated).
With the solid colored and smooth Wheelskins, there's only one seam at the six o'clock position which means that the feel of that seam is unlikely to ever bother anyone; plus the overall look is smoother and tighter looking because there's only one seam and you don't get the hard to fit spoke areas highlighted by contrasting colors. Also, with one smooth solid color, the Wheelskins will look most like OEM, and even more so if you get black.
Tip #1: I don't know if it's been mentioned in this thread, but one way to get a smoother fit on the spokes is to not tighten the "dummy" stitches on the spokes very much. Once you get past the spokes' dummy stitches, you can resume tightening the real stitches as much as you can.
Tip #2: I think that wearing a glove while you tighten stitches is the best way to get tight stitches. With a glove (I use those cheap cotten work or moving gloves with those little rubbery nubbies on the palms and fingers), you won't have the thread cutting into your hand while you pull, and you'll be able to use all your might to tighten stitches. One PriusChatter suggested using a crochet hook, but I can't see a crochet hook tightening as well as a gloved hand pulling hard. Other PriusChatters suggested using needle nose pliers to pull the thread; but again, I can't see pliers pulling as hard as a gloved hand. Also, using needle nose pliers might damage or cut the thread with either the finer teeth or the finer edges that needle nose pliers frequently have.
Best regards, Tom
07 Magnetic Gray #2 - GY TripleTreds 195/60R15, BT Tech Stiffening Plate & Strut Tower Brace, Philips X-Treme Power Headlights, Webasto 4300 Sunroof, Sharkfin Antenna, Chrome Wheelskins Wheel Covers & Door Handles, BumperDefender.com Bumper Guard Strips, Body Side Moldings & Rear Bumper Protector, NoBump.com License Plate Screw Bumpers, Bumper Bully, Sheepskin Seat Cover, Leather Steering Wheel Cover, Leather Center Console Cover, Center-Hump Litter Basket, Non-Slip Pads, Dalmatian Bobble Heads.
Boo is offline
The Following User Says Thank You to Boo For This Useful Post:
zonie911 (09-26-2009)
cover, steering, wheel, wheelskins
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-accessories-modifications/66559-wheelskins-steering-wheel-cover.html
Wheelskins (Steering wheel cover) - PriusChat Forums This thread Refback 08-04-2009 01:45 PM
My wheelskins steering wheel tredstone Gen II Prius Modifications 22 09-21-2009 11:03 PM
Wheelskins Steering Wheel Cover mrblaise Gen II Prius Modifications 25 03-21-2008 02:06 AM
Wheelskins Steering Wheel Cover Scafremon Gen II Prius Modifications 3 11-16-2007 10:31 PM
Black Scuff Marks on Wheelskins steering wheel cover NoMoShocks Gen II Prius Main Forum 6 08-26-2007 12:48 PM
FS: Wheelskins Steering Wheel Leather Cover silentak1 Private Sales 4 10-17-2005 05:36 PM
