This is a discussion on DIY HOW TO: Fix your cargo net hook (pics!) within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; I posted an alternative way to mount your cargo net here: http://priuschat.com/forums/gen-iii-...-solution.html But for those that would rather use the ...
Old 08-22-2009, 05:49 PM   #1
porschett
porschett's Avatar
Default DIY HOW TO: Fix your cargo net hook (pics!)
Cargo Net Fix! (another solution)
But for those that would rather use the factory hook point and find the panel separating, here's a fix:
Tools needed: 1) two M6x40 flat head bolt and washers 2) phillips head screwdriver 3) Wire 4) Plier
The problem with the current mounting of the hook is that it's secured to a plastic panel that is only secured by one screw. Any tension on the hook will "pull" the plastic.
Credit to member "HTMLSpinnr" for the idea, but the fix is to actually secure the hook to a second panel in the back which is better secured to the rear pillar. It took me around 15 min once you've sourced the right parts.
Before
Note the separation. This is w/o tension. It's even worse when you mount the cargo net
After
No separation even w/ tension on the net
New M6x40mm bolt and washer compared to OEM fastener:
Step 1)
Uncrew the phillips head screw:
Step 2)
Uncrew the cargo hook and drill through the existing hole all the way through the back panel. You may want to take a look behind the first panel to see what it is you are trying to drill. Use a bit that is about 1/8" larger than the M6 bolt
Step 3)
Here's the trick: Get yourself a wire and loop the end. This will be used to fish the new bolt through the back panel. There's not a lot of room behind the back panel and you'll probably end up dropping the bolt down in the cavern if you don't fish it correctly.
Now insert the wire from the front through the second panel and secure the new bolt:
Step 4)
Now carefully pull on the wire and reposition the bolt so that it passed through both panels.
Step 5)
Next take a plier and hold the new bolt in place while you screw on the hook and you're done!
Enjoy!
David
porschett is offline
The Following 5 Users Say Thank You to porschett For This Useful Post:
blueumbrella (10-02-2009), Edward Walsh (08-22-2009), fromano (08-23-2009), jestoy7 (08-24-2009), Snowbell (08-22-2009)
Old 08-22-2009, 05:53 PM   #2
jay_man2
jay_man_also
jay_man2's Avatar
Default Re: DIY HOW TO: Fix your cargo net hook (pics!)
Great photo-documentary. It will be interesting to compare your fix to the official fix.
jay_man2 is online now
Old 08-22-2009, 06:00 PM   #3
radiocycle
radiocycle's Avatar
Model: II
Excellent fix porschett, and nice job with the pics! I'm still kind of looking for Toy to do a recall or something but I may soon tire of waiting and use this procedure. Thanks for the clear instructions.
radio
radiocycle is offline
Old 09-30-2009, 04:34 PM   #4
kash
kash's Avatar
Model: V
Package: Adv. Technology
i dont think our cargo net screws on like that
kash is offline
Old 09-30-2009, 04:50 PM   #5
Holbrook22
Thanks for the photos and description. Excellent job.
Holbrook22 is offline
Old 10-01-2009, 08:52 AM   #6
bighouse
bighouse's Avatar
hmmmm...I'm not seeing the images....anyone???
bighouse is offline
Old 10-01-2009, 12:42 PM   #7
a priori
Canonus Curiosus
a priori's Avatar
Model: V
Friends: 18
Must be your browser, as I've seen a few posts referring back to the pictures (and I've seen them since the original post).
a priori is offline
Old 10-01-2009, 07:20 PM   #8
SlowTurd
I LIKE PRIUS'S
SlowTurd's Avatar
i got my car 1 week ago
the new hook looks like it came from home depot
SlowTurd is offline
Old 10-03-2009, 02:16 PM   #9
kash
kash's Avatar
Model: V
odd, the one i got has one of thoes push button type things... its not like yours
kash is offline
Old 10-05-2009, 09:36 PM   #10
janice45
Dudley Girl
janice45's Avatar
David did a great job on the fix I have one modification though I used 6mx 30 bolts the others(6mx40) were just too long me
Thanks David it works great I will still getthe fix when it finaly happens but at least I wont loose any plastic pieces till then .
OH ya the hooks will hold grocery plastic bags just great also
janice45 is offline
cargo, diy, fix, hook, net, pics
OEM Cargo Mat - Pics dogllama Gen III 2010 Prius Accessories and Modifications 5 07-31-2009 08:40 PM
Lost cargo cover hook mar19martin Gen II Prius Care, Maintenance and Troubleshooting 2 11-23-2008 07:08 PM
For Sale, Floor mats, cargo mat, cargo net, spare key fob, autodimming mirror. toasteeroastee Private Sales 4 10-23-2007 12:15 PM
Horizontal cargo net pics fo0bar Gen II Prius Main Forum 4 06-21-2007 12:33 PM
cargo net pulled from hook TheNJDevil Gen II Prius Care, Maintenance and Troubleshooting 6 12-28-2005 11:45 AM
