This is a discussion on Disassemble Center Console (for Katzkin) within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by radioprius1 I am not insulting anything in any way. Is it possible to go back to the ...
Old 10-04-2009, 09:23 PM   #11
eric0213
Model: II
Default Re: Disassemble Armrest on Center Console (for Katzkin)
Originally Posted by radioprius1 View Post
I am not insulting anything in any way. Is it possible to go back to the installer and have him get all those wrinkles out? I would not have accepted that installation. These are katskinz seat replacements right? They should fit tight like a glove.
The wrinkles don't bother me. The photos make it look worse than it actually is. Maybe it's because I had been crawling around the car, kneeling on the car seats, etc. I went out to the car to double check, and the leather isn't tight against the seat, but it's not loose either.
Reading around, people have said that wrinkles work themselves out over time. Whether they are referring to actual wrinkles (from folds of packaging) or the tightness of the fit, I'm unsure. Wrinkles I can understand working themselves out, tightness, not so much. Unless after some humidity, the leather shrinks (like how golf gloves shrink).
I've seen things about how the installer steams the seats to remove the wrinkles, maybe that's adding that humidity to shrink the leather.
When I get the armrest off and take it back to finish the install, I'll tell them to get the wrinkles out.
eric0213 is offline
Old 10-04-2009, 09:47 PM   #12
eric0213
Model: II
Default Re: Disassemble Center Console (for Katzkin)
So I played around with the armrest this afternoon. If you slide the armrest back, it exposes four screws on the bottom side of the armrest in the back (by laying down on the backseat floor). Removing those four screws separates the cloth portion of the armrest from the console.
However, about 3-4 inches from the front of the armrest, there's something (more screws I assume) preventing the entire armrest from coming off. But I can't figure out how to get to the screws, or whatever is attaching. Any ideas?
eric0213 is offline
center, console, disassemble, katzkin
easy way to remove center console drawer or take apart console? cwerdna Gen II Prius Main Forum 2 08-06-2007 03:24 AM
Center Console ibcs Gen II Prius Audio and Electronics 6 05-23-2006 08:35 PM
center console newsking_1991 Gen II Prius Main Forum 1 12-15-2005 03:32 AM
Changing/Adding Center console and ceiling console ggarman Gen II Prius Main Forum 2 03-16-2005 03:09 PM
center console justwatchme Gen II Prius Care, Maintenance and Troubleshooting 4 03-08-2005 12:07 AM
