| This is a discussion on Tinted tail lights, now complete with pics. within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by Anthony Hey radioprius, I just called my brother in law who is a Washington state patrol officer. ... |
| | #21 | |
| 2010PriusWannabe-Now an owner! Join Date: Apr 2009 Location: Leesburg Florida USA
My Car: 2010 Prius Model: V Package: No Package Thanks: 195
Friends: 4 | Quote:
RCW 46.37.200: Stop lamps and electric turn signals displayed. RCW 46.37.200 Stop lamps and electric turn signals displayed. (1) Any vehicle may be equipped and when required under this chapter shall be equipped with a stop lamp or lamps on the rear of the vehicle which shall display a red or amber light, or any shade of color between red and amber, visible from a distance of not less than one hundred feet and on any vehicle manufactured or assembled after January 1, 1964, three hundred feet to the rear in normal sunlight, and which shall be actuated upon application of a service brake, and which may but need not be incorporated with one or more other rear lamps. (2) Any vehicle may be equipped and when required under RCW 46.37.070(2) shall be equipped with electric turn signals which shall indicate an intention to turn by flashing lights showing to the front and rear of a vehicle or on a combination of vehicles on the side of the vehicle or combination toward which the turn is to be made. The lamps showing to the front shall be mounted on the same level and as widely spaced laterally as practicable and, when signaling, shall emit amber light: PROVIDED, That on any vehicle manufactured prior to January 1, 1969, the lamps showing to the front may emit white or amber light, or any shade of light between white and amber. The lamp showing to the rear shall be mounted on the same level and as widely spaced laterally as practicable, and, when signaling, shall emit a red or amber light, or any shade of color between red and amber. Turn signal lamps shall be visible from a distance of not less than five hundred feet to the front and rear in normal sunlight. Turn signal lamps may, but need not be, incorporated in other lamps on the vehicle. (3) Any vehicle may be equipped and when required under this chapter shall be equipped with a center high-mounted stop lamp mounted on the center line of the rear of the vehicle. These stop lamps shall display a red light visible from a distance of not less than three hundred feet to the rear in normal sunlight, and shall be actuated upon application of a service brake, and may not be incorporated with any other rear lamps. [2006 c 306 § 3; 1977 ex.s. c 355 § 17; 1963 c 154 § 15; 1961 c 12 § 46.37.200. Prior: 1955 c 269 § 20; prior: 1953 c 248 § 2, part; 1947 c 267 § 4, part; 1937 c 189 § 23, part; Rem. Supp. 1947 § 6360-23, part; RCW 46.40.090, part; 1929 c 178 § 1, part; 1927 c 309 § 15, part; RRS § 6362-15.]
__________________ Dean in Central Florida 2010 Prius V Barcelona Red/Bisque received 6/13. It's great to be on the Prius Owner Team! Last edited by DeanFL; 10-01-2009 at 07:25 PM. | |
| | #22 | |
My Car: 2010 Prius Model: N/A Package: N/A Thanks: 34
But please don't sell the marmut short. They aren't often heralded as a vicious beast - but they are rumored to be colorblind, and have a nasty taste for radiator fluid ( ). Many a car radiator tubes have been dissected by these creatures in national parks nationwide. They are low to the ground, so likely more immune to the tinted Prius lights. | |
| | #23 |
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 21
Friends: 9 | 1. Let's keep this thread on track. You've both made your arguments, now let's end it with that and stop the back and forth name calling / personal attacks. Discussion is good and disagreement is always inevitable on the internet but sometimes it has to be either dealt with in an adult manner or just ignored. Let's agree to disagree and end it at that or board rules will have to be followed. Don't take any of this as a threat, I just want this thread to continue w/o anymore needless attacks from either side. Your points have been noted radioprius and Anthony has heard you... 2. I personally like the way it looks. Would I do it to my car, no, because here in NYC they'd pull you over to not only give you a ticket for them but for something else on the car... Many of the 'kids' do them around here on their Infiniti's, Lexus' etc and while not as bright as factory people aren't running into each other because of the tinted taillights either... Tinted taillights is just one of those things that if a cop needs a reason to pull you over, he;ll use it to his advantage. Will every cop pull you over for them, no, but it gives them a reason. Is it legal? No covering which obstructs the normal intensity of the bulbs is legal, not even heavy dirt or mud... They can pull you over for that the same as tint over the lenses.
__________________ Mark - Priuschat Moderator & Prius Expert ![]() "Facebook - Ask An Expert" I am not employed by Toyota, and the opinions expressed by me as a Prius Expert are not those of Toyota. Last edited by Paradox; 10-01-2009 at 08:05 PM. |
| | #24 |
| Member Join Date: Sep 2009 Location: Western MA
My Car: 2010 Prius Model: V Package: Navigation Thanks: 177
Friends: 1 | Is that the same as window tint material? |
| | #25 |
Friends: 9 | I don't think it is normal window tint, so if it in fact not did they have different levels of tint Anthony at the place you had the work done? Different colors of tint available? I wonder if a red tint could be applied over the brakelight area and bottom area to make them look like those way overly priced taillight units at sigma... |
| | #26 |
| Dr Curious Join Date: Aug 2009 Location: Louisiana
My Car: 2010 Prius Model: II Package: No Package Thanks: 144
Friends: 0 | |
| | #27 | |
| Senior Member Join Date: Aug 2009 Location: Pacific Northwet
My Car: 2010 Prius Model: II Package: No Package Thanks: 3
Friends: 0 | No, it is much thicker, and more resistant to scratches. Quote:
As someone posted earlier, if a officer needs a reason to pull you over, they will use it to their advantages. I have a very illegal, very dark tint on my truck windows. In 7 years, I have never been stopped for it. I have been stopped, but I roll both windows down and turn my interior light on. If you respect the officer, they will not give you any grief, one even commented on the tint, and he also told me he appreciated me doing what I did to make him more comfortable. Also, our LED lights are already brighter than a regular bulb, so even by tinting the lights, we may still have a brighter output than standard lights. If I really wanted to take a pic from 500 feet, I could, but I really do not care to answer to anyone on an internet board. If I get stopped by a police officer, we can pull out the tape measure. the other thing is, this is not a discussion on if they are legal or not, I simply wanted to show what they looked like tinted. People got way off track. Last edited by Anthony; 10-01-2009 at 08:42 PM. | |
| | #28 |
| Junior Member Join Date: Jul 2009 Location: St Louis, MO
My Car: 2010 Prius Model: II Package: Base Thanks: 1
Friends: 0 | Looks great - I've been thinking about doing the same thing on mine. I'll make sure not to post pics on this forum if I do. |
| | #29 |
| Senior Member Join Date: Mar 2009 Location: Camarillo, CA
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 4
Friends: 2 | Wow Anthony, I'd say you opened up a can of worms. Me personally, I like it and have every intention on doing the same. Was waiting for Lamin-X to have precut kits available. You can get them in a few different shades of tint as well as they have a couple other colors. Will most likely be the lighter of the bunch just to tone down the chrome and even considering maybe the red film to look like the ones available on Sigma's site JDM style. Either way, thanks for sharing the pics. Car looks great. Sorry about the wheels being gone already. There's a ton of aftermarket stuff out there for the kind of money you're looking to spend. Good luck!
__________________ 2010 Prius V w/ATP: Blizzard Pearl/Charcoal Interior 35% tint on the front doors/20% tint on everything else 17x7 Enkei EKM3's in Gunmetal Grey (For Now) Hertz Audio 3-way Component Speakers Custom Installed in the Front Hertz Audio 6 1/2" Coaxial Speakers in the Rear Doors Hertz Audio High Energy 10" Sub in Custom Fiberglass Enclosure JL Audio HD 900/5 5ch. Amp Arc Audio Mini Amp 3000k HID Fog Lights LED Interior Lighting JDM Signal Mirrors More to come... |
| | #30 |
My Car: 2004 Prius Model: N/A Package: Base Thanks: 128
Friends: 33 | The tint used by the OP is rather light, I don't see it being a problem. Another poster had very dark tint ![]() This was way too dark which the poster acknowledged himself. My "Murdered Out Prius" Project I think what you have done with your tail lights is very nice. The stickers on the window are not to my liking but who gives a flying fig, it isn't my car, it's yours. |
| complete, lights, pics, tail, tinted |
| Tail and license plate lights went out -- brake lights work | dialwmd | Gen II Prius Care, Maintenance and Troubleshooting | 14 | 06-29-2009 07:44 PM |
| 2006 Prius Tail Lights Tinted Red *Trade* | SaeGai06 | Private Sales | 2 | 06-25-2009 02:41 PM |
| Trade Tail lights? 2007 Clear for Tinted Version | mtm | Gen II Prius Main Forum | 3 | 06-17-2007 11:17 AM |
| Head lights/ tail Lights don't work | hikerdave | Gen II Prius Main Forum | 5 | 04-13-2006 08:34 AM |
| how to remove complete tail lite assembly,05 | fuelsipper | Knowledge Base Articles Discussion | 6 | 11-02-2005 01:34 PM |
