| This is a discussion on OEM Fog Lights VS Non-OEM Covers With Aftermarket Kit VS Blinglights within the Gen III 2010 Prius Accessories and Modifications forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by mgb4tim that's a pretty good idea. Is there a reason NOT to have them on with your ... |
| View Poll Results: Do you have fog lights on your 2010 Prius? | |||
| Yes, they came with the car as original equipment | | 3 | 11.11% |
| Yes, they are Blinglights | | 0 | 0% |
| Yes, they were retrofitted using all OEM parts | | 1 | 3.70% |
| Yes, they were retrofitted using some aftermarket parts | | 4 | 14.81% |
| No, I don't have fog lights | | 19 | 70.37% |
| Voters: 27. You may not vote on this poll | |||
| | #11 |
| Dr Curious Join Date: Aug 2009 Location: Louisiana
My Car: 2010 Prius Model: II Package: No Package Thanks: 122
Friends: 0 | |
| | #12 |
| Senior Member Join Date: Jul 2009 Location: Adams, MA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 87
Friends: 4 | As previously mentioned, the DOT marking is the only meaningful difference between the $40 kit and the OEM lights. You're stuck with the same OEM cover/adapter thingies no matter which lights you get, unless you want to hack up the blanks and do the blinglight thing. So the only real decisions in my mind are: 1. Do you care about DOT markings? If not, get the Yaris eBay kit. If yes, buy the OEM lights. 2. Which wiring method to use? You have 3 main choices:
| The Following User Says Thank You to rachaelseven For This Useful Post: | radioprius1 (10-31-2009) |
| | #13 |
| Junior Member Join Date: Sep 2009 Location: Raleigh,nc
My Car: 2010 Prius Model: III Package: Solar Roof Thanks: 0
Friends: 0 | Best visibility in thick fog is with fog lights and sidelights only. To be forced to have headlights on at the same time sounds to me counter-productive. I used OEM kit with dashboard switch circuit only operable with ignition on. This seemed the easiest installation and also the most practical. |
| | #14 | |
| Prius Admirer Join Date: Aug 2009 Location: Northern Nevada
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 16
| aftermarket, blinglights, covers, fog, kit, lights, nonoem, oem |
| blinglights fog light | snowykim | Gen III 2010 Prius Accessories and Modifications | 20 | 10-24-2009 05:36 PM |
| Anyone installed aftermarket leather seat covers? | sdserene | Gen II Prius Modifications | 9 | 10-08-2009 11:51 AM |
| Fog Lights--Has Anyone Installed Aftermarket Fog Lights on a 2010 | mr.scott.com | Gen III 2010 Prius Main Forum | 6 | 08-30-2009 09:38 PM |
| Aftermarket driving lights | flydoc | Gen II Prius Modifications | 16 | 06-30-2008 10:49 AM |
| anyone changed the fog lights to white lights if so does it math the color of the LED headlight? | sea-horsea | Gen II Prius Main Forum | 7 | 02-05-2008 03:15 PM |
