| This is a discussion on 2010 Prius Bluetooth A2DP & Iphone 3.0 within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by newbie101 Just so everyone knows, bluetooth streaming is supported by the port installed bluetooth, too! Haven't used ... |
| | #11 |
| Senior Member Join Date: Jan 2009 Location: Chicagoland, IL
My Car: 2010 Prius Model: V Package: Navigation Thanks: 173
Friends: 8 | Glad that you prefer the Audio cable. Myself, and many others here feel that the Bluetooth streaming sounds much clearer than the audio cable. Is there a reason that you prefer the cable, or is it just a personal preference. |
| | #12 | |
| Member Join Date: Jun 2009 Location: New Haven, CT
My Car: 2010 Prius Model: II Package: No Package Thanks: 8
Still, it was a pleasant surprise to learn that it works even with the Port Installed BT on a Prius II. | |
| | #13 |
Friends: 0 | I take it back. I actually tried the BT streaming from my iphone today for an extended period of time. The quality was just fine by me, and the ease of it was fantastic. I think I just had it in my head that it would be inferior to an actual connection. Who knew? Apparently eglmainz. I stand corrected PC community! |
| | #14 | |
| Junior Member Join Date: Jun 2004 Location: OHIO
| | #15 | |
| Junior Member Join Date: Jul 2009 Location: CA
My Car: 2010 Prius Model: II Package: #2 Thanks: 0
| | #16 | |
| Junior Member Join Date: Jul 2009 Location: Plainfield
Please explain how you paired the iPhone with the stereo. I don't see where that is done. When you enter the car next time how do you select the iPhone on the stereo? Thank you. opus2k9 | |
| | #17 |
| Senior Member Join Date: Jul 2009 Location: Colorado
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 10
Friends: 0 | I'm stumped by the Bluetooth audio streaming. If you can help me with specifics, I'd appreciate it. I have a iPhone 3GS and a GIII Prius IV with Navigation package. I was able to make the connect with my iPhone as a phone very easily. Now I don't see any way to connect the iPod function of my 3GS. In the Audio setup screen the BT tab is grey and I have not figured out any way to make this tab active. Do I have to remove the phone connection, then connect the 3GS as a Audio device through the iPod? If I make the audio connection, will my phone still function? Thanks, --TK |
| | #18 | |
| ggood Join Date: Jan 2004 Location: Houston, Texas
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 69
Friends: 6 | Quote:
1. press Setup button (right of nav screen) 2. touch Audio (onscreen button) 3. touch Bluetooth Audio Settings (onscreen button) 4. touch Edit (onscreen button) for Passcode 5. enter same passcode as used for iphone (default 1212?) 6. touch OK (onscreen button) to go back to Bluetooth Audio Settings 7. touch Register (onscreen button) for Bluetooth Audio 8. on iphone, start bluetooth search (settings, general, bluetooth) 9. on iphone, highlight car multimedia (probably 2nd device found) and press connect 10. on iphone, enter the passcode Probably doesn't matter whether you press register on car first, or bluetooth searching on iphone first. I don't remember for sure if I got an in use message, but if I did, it didn't matter. Once I restarted the car, it connected for both phone and audio player. I also don't know if changing the passcode is really necesary, but I did it based on someone else's post. Other people have said they deleted the phone and setup bluetooth audio first, which resulted in pairing the iphone for both audio and phone at once. | |
| The Following User Says Thank You to ggood For This Useful Post: | TracyJ (10-13-2009) |
| | #19 |
Friends: 0 | I've answered my own question; I've spent some time in my car getting my iPhone 3GS phone and iPod Paired to the Prius Bluetooth. Yes, I had to discard the first connection I made between my iPhone phone function and the Prius. The following sequence gives me both iPod audio streaming and iPhone function from my iPhone 3GS to my GIII Prius IV with Solar Roof and Navigation package: Go to the Audio Setup screen and Connect your Iphone 3GS iPod. When I received the Connection Successfully Made message, I confirmed I could play songs on my iPhone 3GS iPod through the Bluetooth connection on the car audio system. Next, I went to the phone set up and connected to the iPhone 3GS phone functions. This connection did not ask to input another connection code. It found the connection. I then made a call to confirm this worked. When I hung up the iPhone 3GS started playing the same song I had previously tested. I stopped the song in the iPhone 3GS iPod function and everything seems to be working. There appears to be no need to purchase an after market product nor the Toyota factory iPod cable, unless you have a older iPod. For example, I have a older 60GB iPod Photo (4th Gen) I could plug in to play music, which would permit me to conserve the battery on my iPhone 3GS. --TK |
| a2dp, iphone |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/64421-2010-prius-bluetooth-a2dp-iphone-3-0-a.html | ||||
| New Prius - everything you need to know | Toyota UK news, reviews, video and pictures | Today Tomorrow | This thread | Refback | 11-17-2009 02:13 PM | |
| New Prius - everything you need to know | Toyota UK news, reviews, video and pictures | Today Tomorrow | This thread | Refback | 11-11-2009 10:21 AM | |
| iphone G3 & Prius Bluetooth | lapriusowner | Gen II Prius Main Forum | 29 | 09-05-2009 04:50 PM |
| iPhone OS 3.0 to support Bluetooth music streaming in 2010 Prius | Danny | Prius and Hybrid News | 19 | 07-11-2009 07:02 AM |
| 2010 Prius to have A2DP Enabled - Bluetooth Music Streaming | Danny | Prius and Hybrid News | 24 | 06-21-2009 06:56 AM |
| iPhone: Do you think Apple iPhone Bluetooth will be Prius Compatible? | osXcode | Gen II Prius Audio and Electronics | 21 | 06-30-2007 09:18 AM |
| iPhone, Bluetooth 2 and the Prius | hdrygas | Gen II Prius Audio and Electronics | 0 | 01-14-2007 01:48 PM |
