| This is a discussion on What cell phone to get??? within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; I just ordered my GenIII IV w/solar roof and want to know what cell phone will work with the Prius ... |
| Member Join Date: Mar 2009 Location: Orlando, FL
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 10
Friends: 0 | I just ordered my GenIII IV w/solar roof and want to know what cell phone will work with the Prius and AT&T networks?? Currently I have a Nokia flip phone that came with the cell sign up. I just need to make and receive calls. No internet or email. Any suggestions?? I have read that some phones will work better than others. |
| Senior Member Join Date: May 2008 Location: SF Bay Area
My Car: 2010 Prius Model: V Package: Navigation Thanks: 58
Friends: 2 | Try this site: Toyota Bluetooth Phone |
| Senior Member Join Date: May 2009 Location: Idaho
My Car: 2010 Prius Model: III Package: Navigation Thanks: 13
Friends: 1 | I have a unlocked Nokia N85 and when i got it i just moved the ATT sim card from the old razr and put it in the N85. No problems with that and it synced with the bluetooth phone sys in my Gen III model III with nav and transfered all my contacts. I have NOT tried streaming music but it handles phone calls just fine. That's one of the things i like about ATT that you can pretty much stick your sim card into a new phone and it works fine. BTW i didn't buy the phone from ATT, i got it from Amazon Last edited by LRKingII; 06-30-2009 at 09:23 PM. |
| Junior Member Join Date: Jun 2009 Location: South Florida
My Car: 2010 Prius Model: V Package: #5 Touring Thanks: 0
Friends: 0 | I JUST WENT THROUGH THIS. I WENT TO THE at&t STORE AND WE TRIED SEVERAL PHONES WITH NO LUCK. WE THEN FOUND A PHONE THAT WORKED FINE (I FORGET WHICH ONE). AFTER WE DROVE HOME AND SHUT OFF THE CAR I DECIDED TO PLAY WITH THE NEW PHONE AND THE BLUETOOTH. I RE STARTED THE CAR AND THE PHONE NEVER CONNECTED AGAIN. I DROVE BACK TO THE STORE TO FIND OUT THAT THE PHONE IS NOT COMPATABLE. I THEN BOUGHT A SONY W760A WHICH CONNECTS TO THE THE BLUETOOTH FINE. I THEN BOUGHT THE W350 FOR THE WIFE WHICH IS A SONY ALSO. BOTH PHONES ARE BOTH NORMAL PHONES AND DOES NOT REQUIRE A DATA PLAN TO BE PURCHASED. GOOD LUCK! |
| The Following User Says Thank You to twentyten For This Useful Post: | rlr66 (08-01-2009) |
| Member Join Date: May 2009 Location: San Diego, CA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 0
Friends: 0 | I have the LG Chocolate and it works very well but it will not transfer the contact list. I had to input all my contacts manually. |
| Senior Member Join Date: Apr 2009 Location: Scottsdale, Arizona
My Car: 2010 Prius Model: III Package: N/A Thanks: 25
Friends: 1 | I had no problem pairing my Blackberry Curve (AT&T) with system. The few times that I've used the phone in the car, audio reception and transmission was fine. |
| The Following User Says Thank You to dbacksfan For This Useful Post: | rlr66 (08-01-2009) |
| Senior Member Join Date: May 2009 Location: New Orleans
My Car: 2010 Prius Model: III Package: N/A Thanks: 5
Friends: 2 | I get great connectivity and call quality with my Blackberry. |
| The Following User Says Thank You to nineinchnail1024 For This Useful Post: | rlr66 (08-01-2009) |
Friends: 10 | i checked the verizon options on the Toyota BT site and the list comes no where close to what will connect. i have a LG 11000 enV touch, a Palm Centro, Blackberry Storm and LG 10000 Voyager, all connected, all transfered contacts. was actually pretty easy process. for a possibly better link for verizon options Bluetooth® Car Kit/Accessory Support Matrix on the Chocolate?? what version is it? the site above says it works with all versions except that the 8500 and 8550 dont support multiple entries (iow, more than one # for a single name entry). if your phone is not working, you might want to make sure you have the latest flash upgrade (this requires you to take to store to connect to their machine). the Chocolate was a work in progress the entire time it was available (which means it was a piece of garbage) so multiple updates were released to fix one bug after another. supported BT profiles by models on verizon http://support.vzw.com/pdf/BT_Chart_Handsets.pdf
__________________ My Blue 2010 : Last tank 541.9 @ 49.48 pump (56.7 MFD) 5.54 CPM, 21 MPH, Lifetime:5442.2 miles 56.5 MPG pump. (62.22 MFD) 4.72 CPM. Summer MPG 57.4 Winter: 49.5 My 2006 SPM: Last tank 376.6 miles @38.21 pump (40.8 MFD) 7.17 cpm winter mpg 49.64 summer mpg 53.41 lifetime: 42,563.5 miles 51.5 mpg pump (52.7 mpg MFD) 5.51 cpm My 2007 Zenn total "fuel cost" $166.58 on "about" 9599.7 miles. 1.74 cents per mile (granted i plug in for free at work!!) My Plate: DUALPWR (Dual Power) Last edited by DaveinOlyWA; 06-30-2009 at 11:38 PM. |
| The Following User Says Thank You to DaveinOlyWA For This Useful Post: | lauren80ryan (07-15-2009) |
| cell, phone |
| Cell phone guidance please; new cell owner | Freedom | Gen II Prius Audio and Electronics | 2 | 01-27-2009 09:12 PM |
| How To Download Phone Book From Cell Phone? | abcohen | Gen II Prius Audio and Electronics | 3 | 05-03-2007 09:38 PM |
| Fuel Cell Cell Phone Charger-will go great with your Prius | hb06 | Fred's House of Pancakes | 3 | 12-07-2006 09:03 PM |
| SKS FOB and Cell Phone Together? | jmccord | Gen II Prius Audio and Electronics | 6 | 07-01-2006 02:51 PM |
| Cell phone use | Poppajack747 | Gen II Prius Audio and Electronics | 16 | 07-23-2005 04:48 PM |
