2010 prius/Iphone 3.0 bluetooth connection question
| Junior Member Join Date: Jul 2009 Location: CA
My Car: 2010 Prius Model: III Package: Navigation Thanks: 0
Friends: 0 | I have a question concerning bluetooth connection with my prius. I was wondering if it is possible to connect the iphone to play music and as a phone. If so could one of you please help me figure out how to connect it properly. |
| Senior Member Join Date: Feb 2009 Location: Vancouver
My Car: 2010 Prius Model: N/A Package: Premium w/ Solar Cells - CA Thanks: 10
Friends: 0 | It should explain how to do that in your Nav instruction package. I know you can do it but I don't have Nav so I can't tell you how to do it |
| Junior Member Join Date: Jun 2009 Location: Fairfax, Va
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 1
Friends: 0 | When we picked up our new car on Thursday, they told us during our orientation that you could use Bluetooth for music or to connect the phone for calls. Either but not both. The Bluetooth protocol allows one but not the other. He also went on to say that they recommend that if you listen to music you use a cable into the AUX since it doesn't drain the iPhones battery so much. |
| Junior Member Join Date: May 2009 Location: Daphne, AL
My Car: 2010 Prius Model: V Package: Navigation Thanks: 1
Friends: 0 | I have a pkg V with Nav and an iPhone 3GS. I have both the audio and phone connected. I can stream music, podcasts, etc to the car; then if a call comes in or I want to make a call, all the phone functions are still available, and it shows up on the nav screen. When I first tried to setup the bluetooth pairing, I could only get one or the other. But for some strange reason I finally got both to work by connecting the bluetooth audio first, then the phone. You have to pair the phone twice. Now when I get in the car, and turn on bluetooth on my iPhone, it automatically connects to both. When I select "BT" on the audio screen of the Nav, it automatically starts playing MP3s on shuffle. Plus all the phone functions are still available. |
| Thanked by 3 Users: |
| Senior Member Join Date: Jun 2009 Location: Philadelphia
My Car: 2010 Prius Model: III Package: Navigation Thanks: 6
The music is also working perfect while driving in areas where the G3 network exists, I can play music from Pandora, I also got ooTunes and can listening to streaming Internet Radio from around the world, thousands of radio stations. Of course it will play your saved IPOD music regardless of network. So the new I-Phone G3S works perfect through Bluetooth. The older I-Phone G3 will work perfect bluetooth for phone only. The Bluetooth audio for music does not recognize the G3 only phone, but you can still hook the I-Phone G3 directly into the Prius stereo via the stereo auxiliary jack using a small stereo cable so you are not missing anything except not using the wire. You will not see songs being played displayed on the Prius Screen either way. The sound quality is excellent either way.
__________________ | |
| ggood Join Date: Jan 2004 Location: Houston, Texas
My Car: 2010 Prius Model: V Package: Adv. Technology Thanks: 142
Friends: 8 | The 3G phone also works for both phone and music. The bluetooth audio streaming is part of the new 3.0 operating system. However, only the gen3 (2010) nav systems support it (gen2 cars do not). |
| Thanked by: | LouieNet (08-01-2010) |
Friends: 8 | Quote:
@Toyota: Behind the Wheel | |
| Senior Member Join Date: Jul 2009 Location: NE Indiana
My Car: 2010 Prius Model: IV Package: No Package Thanks: 41
| Junior Member Join Date: Jul 2009 Location: Canada
My Car: 2010 Prius Model: N/A Package: Technology Package - CA Thanks: 0
Friends: 0 | I picked up my Prius with Technology Package (Canadian version with Nav) three days ago. I paired my 3G iPhone as a phone and as a music player (requires iPhone firmware 3.0). When I first did this the music would play fine until the screen of the iPhone shut off then the music would go wonky. It would cut out and then seemed to fast forward and then cut out again. When I activated the screen of the phone again everything worked perfectly. As soon as the screen saver kicked in the music went out again. This was very frustrating to deal with while I was in stop and go traffic in a brand new car. Once I stopped, I paired it to the audio system again and the problem has disappeared. Now my only issue is that when I shut the music off it forgets where it was in the track so when I start it again it goes back to the beginning. I suspect this is an iPhone issue not a Prius issue. Today I got my first phone call in the car while the music was streaming from the phone. Everything worked beautifully. BTW the music volume gets turned down and directed through the right side speakers when the Nav system voice comes on. You can hear both but the Nav is much more prominent. To set things up I had to pair the phone through the normal BlueTooth pairing in the Info-Phone menu and then pair the phone again as an audio device on the BT tab of the Audio menu. Currently the iPhone firmware 3.0 does not support any of the fast forward/reverse or volume control functions of BT audio. You can pause and play using a button on the BT tab of the Audio screen and use the volume controls of the audio system. |
Friends: 0 | I think it is a iphone issue with the song starting back at the begining rather than pausing. There was another thread in here mentioning that. |
| 2010, bluetooth, connection, prius or iphone, question |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/65881-2010-prius-iphone-3-0-bluetooth-connection-question.html | ||||
| What do I use to plug in my iphone to my Prius? - Yahoo! Answers | This thread | Refback | 04-08-2012 10:42 AM | |
| What do I use to plug in my iphone to my Prius? - Yahoo! Answers | This thread | Refback | 04-08-2012 02:18 AM | |
| Question on iPod adapter for iPhone on 2010 Prius? | yortch | Gen III 2010+ Prius Audio and Electronics | 20 | 08-16-2010 07:38 PM |
| 2010 Prius Bluetooth A2DP & Iphone 3.0 | jalopez | Gen III 2010+ Prius Audio and Electronics | 60 | 05-26-2010 11:03 PM |
| iPhone OS 3.0 to support Bluetooth music streaming in 2010 Prius | Danny | Prius, Hybrid, EV and Alt-Fuel News | 21 | 02-05-2010 08:47 PM |
| iPhone/2007 Prius- losing BT connection on restart | pdadoc | Gen II Prius Audio and Electronics | 3 | 07-25-2008 07:58 AM |
| iPhone: Do you think Apple iPhone Bluetooth will be Prius Compatible? | osXcode | Gen II Prius Audio and Electronics | 21 | 06-30-2007 09:18 AM |
