This is a discussion on Custom subwoofer install within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Lookin' good! What is your interior volume going to end up being? Like .5 cuft? Make sure to put some ...
Old 08-05-2009, 01:15 PM   #21
MikeDS
Model: II
Default Re: Custom subwoofer install
Lookin' good! What is your interior volume going to end up being? Like .5 cuft? Make sure to put some polyfill in it when you're mouting the speaker.
MikeDS is offline
Old 08-05-2009, 02:25 PM   #22
mgb4tim
Noob
mgb4tim's Avatar
Package: Navigation
if that box is PVC, the fiberglass should have popped out with a little persuasion with the tape or foil. I'll give it a test later.
mgb4tim is offline
Old 08-06-2009, 01:18 AM   #23
Silencer2169
I ve been an installer for many years and haven't done much work witht he prius in general. If replacing the OEM radio with a Pioneer D3 will that affect my climate controls, consumption and energy screens at all or just the audio controls for the factory radio. I dont care about loosing the Steering wheel controls I can always get a PAC SW universal down the road for that, Right?
Silencer2169 is offline
Old 08-06-2009, 01:44 AM   #24
hyo silver
awaaay
hyo silver's Avatar
Friends: 63
Originally Posted by nylion View Post
...Once you complete the rear compartment fiberglass, how do you finish off the front?...If someone does make a mould, I will happily buy the enclosure.
Generally, a chunk of mdf is used for the face, which gives more mass and provides a sturdy mounting for the speaker. A custom enclosure made at a professional installation shop could well be several hundred dollars, and a mould is much more work than a one-off.
Originally Posted by WaterbedWarrior View Post
...Still have blue tape and foil sticking to it....
Did you use any kind of wax or spray before laying the glass? That would have helped keep the tape from weakening the fibreglass, and keep the resin from bleeding through to the carpet. Curing times are also very sensitive to temperature - my first attempt with this stuff didn't work at all.
My other high mileage, low emission vehicles are my bicycles and my shoes.
hyo silver is offline
Old 08-06-2009, 05:44 AM   #25
WaterbedWarrior
Going insane!
WaterbedWarrior's Avatar
Model: II
I didn't have any problems with bleed through or release, just the foil and the tape used on the foil overlaps sticking to the fiberglass. I put down a layer of tape then 2 layers of heavy duty aluminum foil.
Have yet to decide if I'm going to do an MDF front or wrap the fiberglass around the front using felt and a sub mounting ring. Will cross that bridge when I get to it.
Best guess is about .6cu ft, but all depends how well the back fits, plus the base is a bit smaller now since I formed it inside the bottom side tray. Will almost definitely be using some polyfill to maximize the minimum space inside the enclosure.
May be pouring the backside this morning, depending on how rambunxious I feel when I get home. My 100 sq ft of sound deadening material arrived yesterday. Girlfriend is already asking for me to put some in her car when I'm done with mine. Still hunting for the best price on a set of 2 ohm Infinity 6x9's to replace the front factory speakers and no real clue what I'm going to do about teh factory tweeters up in the dash. Will decide once I open it up and see what kind of room I have to work with. Getting way ahed fo myself.
WaterbedWarrior is offline
Old 08-06-2009, 07:40 AM   #26
HardcoreWR
Package: Premium - CA
I just wanted to share my own project with you guys
Bestandsoverzicht van /sub-prius/
Greets,
Leon
The Netherlands
HardcoreWR is offline
Old 08-06-2009, 08:23 AM   #27
WaterbedWarrior
Going insane!
Model: II
That's pretty cool, can you still access your spare tire by yourself?
I'm trying for something a little more compact and less intrusive. I need my trunkspace, whether it be hauling luggage or scuba tanks for a dive trip.
Old 08-06-2009, 08:54 AM   #28
HardcoreWR
Yes, the spare tire is under the subwoofer, so what I need to do is just remove the plate with the handles.
Then you see a banana-connector ( http://www.summitsource.com/images/products/CMBDRH.jpg )
Just disconnect it and lift the subwoofer, and there is the spare tire
With an empty trunk it will take 1 minute.
Old 08-07-2009, 07:24 AM   #29
WaterbedWarrior
Going insane!
Model: II
Bought a pair of Infinity Reference 9623i 3-way 6x9's for my front doors.
Picked these 6x9's as they have a very shallow mounting depth of 3" and a 2ohm resistance which means I can use a smaller amplifier.
Will be pairing them with a Rockford Fosgate Punch 250aII (which can put out 125 watts RMS per channel at 2 ohm). Speakers are rated to handle 100 watts RMS, so the amp gives me plenty of headroom for some nice clean sound. Have another Punch 250aII which will be pushing my 10" subwoofer.
Just waiting for it to get a little more light outside, then going to continue fiberglassing my box. Didn't get anything accomplished on it yesterday.
Old 08-07-2009, 08:56 AM   #30
mgb4tim
Noob
mgb4tim's Avatar
Package: Navigation
my Ranger came with 5x7's in the door, I installed 6x9's, but had to stuff them into the door, and attach from the back side.
mgb4tim is offline
custom, install, subwoofer
Subwoofer (Kenwood KSC-SW10) install feedback donwon19 Gen II Prius Audio and Electronics 6 05-11-2009 09:49 PM
Bunch of pre-subwoofer install pictures Quindor Gen II Prius Audio and Electronics 7 08-21-2008 08:39 AM
Kenwood Subwoofer and amplifier install toddhata Gen II Prius Audio and Electronics 13 05-29-2008 11:04 AM
Custom subwoofer enclosure for 04 and 05 Prius viffer_pilot Gen II Prius Audio and Electronics 49 04-14-2007 02:57 PM
Can i install the Priusxm kit even after a subwoofer upgrade Kev1000000 Gen II Prius Audio and Electronics 2 05-24-2005 01:26 PM
