This is a discussion on removing front door 6x9 speakers within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; What happened to the subwoofer box update and pics....
LinkBack (1) Thread Tools
Old 08-25-2009, 05:20 AM   #31
kaptmorgan
Model: V
Package: Navigation
Default Re: removing front door 6x9 speakers
kaptmorgan is offline
Old 08-25-2009, 11:05 AM   #32
WaterbedWarrior
Going insane!
WaterbedWarrior's Avatar
Model: II
Sorry man, work has been keeping me busy. The back of the box is done. I gotta cut a subwoofer mounting ring from MDF. Mount it and then fiberglass it into the front. It will come. Suppose to have this weekend off, so will see what progress I can make.
WaterbedWarrior is offline
Old 08-26-2009, 07:26 PM   #33
SlowTurd
I LIKE PRIUS'S
SlowTurd's Avatar
would changing the door speakers alone improve the sound quality?
and how much an improvement?
SlowTurd is offline
Old 11-03-2009, 01:43 AM   #34
Much More Better
Question regarding swapping speakers for a non-JBL system:
If I'm swapping 6x9" in the front door, what do you with the dash mounted squawkers? Are they simply disconnected? Is the signal going to the 6x9" full range or is there a crossover somewhere? I'm curious because it makes no sense to drop in a full range 3 way 6x9" coaxial speaker if the signal is midrange.
For those who have upgrade to component speakers:
Where have you mounted your tweeters? I'm not keen on custom molded panels for the A-pillars. Can't they just go where the squawkers are? Surface mount is okay but I'd like to see some easy flush mounts.
Much More Better is offline
Old 11-03-2009, 02:03 AM   #35
rrolff
Prius Surgeon
rrolff's Avatar
I've looked at this a bit {IMHO} you really should have something up front. If you look back a bit, I took some pics, and you should be able to put a 3" in the space of the squaker. I believe you'll almost get more from that than the 6x9 - but they should be done as a pair...
Crutchfield has a matched pair (1" and 6x9 Clarion SRP6920M Platinum Series 6"x9" component system at Crutchfield.com ) for like $80 on sale (off brand - but should be good). Your other choice is to find a 6x9 and 3" with similar sensitivities - and get a passive cross-over - when I upgrade, I'll go that route... I found a new head unit does make even the cheap speakers sound OK.
You really should get a 3" up front - it will take a bit of surgery - but it will be worth it in the long run...
Keep in mind - if they aren't loud enough (sensitivity), you are talking external amps...
rrolff is offline
Old 11-03-2009, 12:35 PM   #36
Much More Better
Thanks rrolff for the reply. But I'm missing something here......If I put in a 3" driver in the squawker location, I still need a separate tweeter right? The 3" is more like a midrange. And then maybe a separate bass driver in the 6x9" door location? Or is the 3" a 2way-coaxial speaker?
And the Crutchfield Clarion example you gave me: Does the 1" tweeter go in the squawker location?
Old 11-03-2009, 01:43 PM   #37
Much More Better
I found the front tweeter removal thread and most of my ? are answered.
6x9, door, front, removing, speakers
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/67089-removing-front-door-6x9-speakers.html
Klappergeräusche This thread Refback 10-07-2009 04:13 AM
New speakers in Front Door panel - '06 steveduer1 Gen II Prius Audio and Electronics 9 07-05-2007 12:27 PM
unlock the door without removing the sks from your pocket Mary Snyder Gen II Prius Main Forum 21 06-07-2007 06:45 PM
Scion TC speakers in front door? goodsam Gen II Prius Audio and Electronics 2 02-25-2006 08:18 PM
Nervous about removing door panels/wiring IndyDoug Gen II Prius Audio and Electronics 4 10-28-2005 03:59 AM
Removing Door Panel XravenX Gen II Prius Care, Maintenance and Troubleshooting 4 05-23-2005 11:53 AM
