This is a discussion on Will an iPhone work with the 2010 USB interface? within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by IrishGuyJay The first time I connected my phone (an iPhone 3G running firmware 3.1) I also got ...
Old 10-21-2009, 06:11 PM   #41
gnawfish
Package: Navigation
Default Re: Will an iPhone work with the 2010 USB interface?
Originally Posted by IrishGuyJay View Post
The first time I connected my phone (an iPhone 3G running firmware 3.1) I also got this message, selected "no," and was able to connect.
However, when I connect now I get a message stating that the device is not compatible and only an "OK" button -- no yes/no option on the phone to switch to airplane mode. When I press "OK" on my phone I am unable to connect and cannot see my music on the NAV screen. Has anyone else had this problem or found a resolution?
I have this same exact problem IrishGuyJay. Any luck with finding an answer?
gnawfish is offline
Old 11-06-2009, 10:34 AM   #42
Carnutt
Carnutt's Avatar
This is what I found: the 3G iPhone will work with your car's Bluetooth and download your phone book and utilize the hands-free car controls. If you plug the phone into the usb port with the adapter, it becomes just an iPod mp3 player and apparently disables the phone and will not charge it while connected.
Carnutt is offline
Old 11-06-2009, 12:50 PM   #43
xanmato
xanmato's Avatar
Package: Navigation
Phone: Iphone 3G
Bluetooth: working
USB charging: working
USB integration: working
Everything still works when plugged into USB
Device not compatible fix:
1. Remove bluetooth connection profile from prius (phone section AND audio section)
2. Remove bluetooth connection profile from iphone
3. Restart iphone
4. Plug iphone into USB and integration should work (you still have normal yes/no popup)
5. Re-add iphone to prius (do not re-add bluetooth in audio section, just phone bluetooth)
xanmato is offline
The Following User Says Thank You to xanmato For This Useful Post:
R2Pre2 (11-06-2009)
Old 11-06-2009, 11:18 PM   #44
R2Pre2
Feel the Force!
R2Pre2's Avatar
Model: V
Package: Adv. Technology
Friends: 15
thanks for this summary. i'll try it and hopefully it will work. now...if we can just get the airplane mode pop-up fixed...
R2Pre2 is offline
Old 11-08-2009, 02:21 AM   #45
xanmato
xanmato's Avatar
Package: Navigation
Sadly, the airplane mode popup is here to stay, unless toyota makes a 'works with iphone' certified version. Hardware manufacturers must certify their devices and pay Apple a fee to put a Hardware authentication chip inside the device, otherwise you get the pop up.
xanmato is offline
2010, interface, iphone, usb, work
iPod USB interface mod for 2010 prius mbucklein Gen III 2010 Prius Accessories and Modifications 27 11-11-2009 02:14 AM
Iphone OS 3.0 Review on the Prius 2010 Mike Azami Gen III 2010 Prius Main Forum 98 09-25-2009 12:58 AM
2010 Prius iPhone App seattlebound Gen III 2010 Prius Audio and Electronics 34 09-09-2009 11:54 AM
Installing the Toyota ipod interface kit in 2010 davidsullivan317 Gen III 2010 Prius Accessories and Modifications 7 08-19-2009 09:14 PM
2010 iPod interface pics/info nola_Prius Gen III 2010 Prius Main Forum 27 08-05-2009 05:21 PM
