Go Back   PriusChat Forums > Gen III (2010+) Toyota Prius Forums > Gen III 2010+ Prius Audio and Electronics
OEM/Aftermarket Backup Camera Gen III 2010 Prius
Old 12-03-2009, 07:22 PM   #11
Prius Surgeon
rrolff's Avatar
Default Re: OEM/Aftermarket Backup Camera Gen III 2010 Prius
Originally Posted by deltron3030 View Post
whats the part number for the sony camera you installed? is the sony cam OEM?
There are many OEM'd cameras on Ebay - they will be as good as the Sony. To a search on camera camry... You can spend between $45 and $250 for pretty much the same thing...
rrolff is offline
Old 12-03-2009, 08:07 PM   #12
deltron3030's Avatar
Model: II
awesome! thanks rrolff
deltron3030 is offline
Old 02-13-2011, 05:40 PM   #13
Model: Three
My wife and I bought a 2010 Prius III last October. After each of us backed into objects due to the poor rear vision, we had our local Toyota dealer install an aftermarket rear view camera. We chose a system where the display is in an auto-dimming mirror. We are very pleased with the results and now almost seek out challenging backing up situations.
After several false starts, our Toyota dealer installed a system purchased from Mito Corporation . We got the Auto-dimming mirror with rear camera display and a 180 degree camera that looks just like the #VN2218 Vehicle Rearvision Visual System shown on the Mito web site. The camera mounts just to the right of the rear hatch sensor and looks very much like original equipment.
If you go this route, assemble the system on your living room floor before doing any work to your car. You need to be sure the correct wires and connectors are supplied. We had a few problems that way, and it caused quite a bit of delay in the installation process.
Since the parts from Mito didn’t come with a wire cover to hide the wire as it comes from the head liner to the back of the mirror, we bought a Gentex Rear View Adjustable Mirror Wire Cover.
As I said, we are very pleased with the results. The installation looks like it was done at the factory, and we now have excellent rear vision when backing up. It was more expensive than others mentioned here, but I think it will turn out to be worth the cost.
Ray
RayPB is offline
Old 03-15-2012, 05:14 PM   #14
My Car: 2012 Prius c
Model: Three
Package: Navigation
Ray
How much was this backup camera system? Including the system and installation?
Did you just go to the dealer and ask if they can install it and they said yes?
Thanks,
Michael K.
meehow09 is offline
2010, backup, camera, gen, iii, oem or aftermarket, prius
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/69619-oem-aftermarket-backup-camera-gen-iii-2010-prius.html
Mi Toyota Prius - CON SENSOR DE APARCAMIENTO Y SIN NAV ¿posibilidad de incorporar camara? - Tuning Prius 3G This thread Refback 11-29-2010 10:40 AM
OEM/Aftermarket Backup Camera Gen III 2010 Prius - PriusChat Forums This thread Refback 09-10-2010 04:59 PM
Sony Backup Camera - 3D Search This thread Refback 07-12-2010 02:37 AM
Mi Toyota Prius - CON SENSOR DE APARCAMIENTO Y SIN NAV ¿posibilidad de incorporar camara? - Tuning Prius 3G This thread Refback 05-15-2010 07:35 PM
OEM/Aftermarket Backup Camera Gen III 2010 Prius - PriusChat Forums This thread Refback 05-10-2010 08:37 PM
Aftermarket Rear-View Camera for Gen III Prius greenbelt Gen III 2010+ Prius Audio and Electronics 13 12-12-2011 12:44 PM
2007 Prius retrofit backup camera? gail1946 Gen II Prius Main Forum 11 05-23-2011 05:52 PM
2010 Prius Backup Camera Night Performance better than expected HTMLSpinnr Gen III 2010+ Prius Main Forum 11 11-11-2009 01:22 AM
aftermarket gps /dvd /cd /backup camera installed caycarem Gen III 2010+ Prius Accessories and Modifications 3 09-14-2009 08:52 PM
Is there an OEM backup camera cable in 2004 prius? SillyBilly Gen II Prius Audio and Electronics 5 01-17-2009 10:33 AM
