| This is a discussion on Disabling KARR alarm horn beep within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; the instructions given thus far are correct. Just make sure when you go from turning to "ON", then "OFF," that ... |
| | LinkBack (4) | Thread Tools |
| | #11 |
| Junior Member Join Date: Jun 2009 Location: San Diego
My Car: 2010 Prius Model: II Package: Base - CA Thanks: 0
Friends: 1 | the instructions given thus far are correct. Just make sure when you go from turning to "ON", then "OFF," that sequence is done with 3 seconds. I've done it to my car and the steps are in the HP3 alarms owner manual as well. I also have the HP3 (High Performance 3). sequence: before you start, make sure your certain you can locate the "valet button" of the alarm system. It is the button immediately behind the flashing led. Usually placed at the lower left corner below the dash (steering column). Upon pressing it, you should feel a slight click. 1)Press "POWER" 2 times, then within a second or two, press "POWER" again to turn off vehicle (does not matter if brake is pushed in). 2)Tap the "VALET" button 3 times and let go. You should hear 2 honks from the horn to confirm "horn honks are off when locking/unlocking via keyfob. Just remember the sequence between POWER on than OFF must be done within 3 seconds. If in the future you want the honks back on when you Lock/Unlock your car, do the same thing. Accept after tapping the valet button, you will hear 1 honk to confirm steps are completed. |
| | #12 |
| Senior Member Join Date: Apr 2007 Location: Los Angeles
My Car: 2010 Prius Model: II Package: No Package Thanks: 9
Friends: 0 | Tried it again in On, but not Ready mode and it worked great. So glad I didn't have to run to the dealer for this! Thanks!! Mike |
| alarm, beep, disabling, horn, karr |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/69621-disabling-karr-alarm-horn-beep.html | ||||
| Karr Auto Alarm Manual - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | 11-19-2009 10:37 AM | |
| Karr Auto Alarm Manual - Kosmix : Reference, Videos, Images, News, Shopping and more... | This thread | Refback | 11-18-2009 06:19 PM | |
| Info.com - karr alarm - www.Info.com | This thread | Refback | 10-25-2009 12:38 PM | |
| Karr Security Systems Links | This thread | Refback | 09-28-2009 03:08 AM | |
| Alarm Horn Beep Disable? | Halfnuts | Gen II Prius Audio and Electronics | 3 | 09-27-2009 06:52 PM |
| Removing KARR Alarm | hilore | Gen II Prius Main Forum | 4 | 02-10-2009 03:28 PM |
| Disabling reverse beep/seatbelt beep on an 06' | Paradox | Gen II Prius Main Forum | 31 | 05-30-2006 10:53 PM |
| Disabling Seatbelt Beep | DougSlug | Gen II Prius Modifications | 6 | 04-03-2006 11:32 PM |
| Disabling the reverse beep (and seatbelt beep) | dougkm | Gen II Prius Main Forum | 1 | 12-01-2003 07:42 AM |
