| This is a discussion on AM-SAT button only gets AM1 within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; This is an odd problem. My radio worked fine until last wednesday, I used SAT radio daily for traffic and ... |
#1 |
| Priusite Join Date: Jul 2009 Location: Miami, Florida
My Car: 2010 Prius Model: III Package: No Package Thanks: 142
Friends: 4 | This is an odd problem. My radio worked fine until last wednesday, I used SAT radio daily for traffic and weather every morning. Now from one day to the next it doesn't even select SAT when I push the AM-SAT button, it only gets AM1. It doesn't go to any other AM such as AM2 if there is one ( I don't know for sure there is, I never listen to AM, but would like to hear if there is an AM2). My trial subscription wont expire until the 11th and even then I should be able to at least select SAT and hear their promotional channel. I haven't been fooling with the radio or surrounding dash panels (lately ;P) and I did try pulling and replacing the jumper in the underhood fuse box. That wiped my mileage info but did not restore the SAT radio. Any ideas? |
| Senior Member Join Date: May 2009 Location: Idaho
My Car: 2010 Prius Model: III Package: Navigation Thanks: 19
Friends: 1 | Quote:
The Sat program is only good (free) for 90 days. If you've had the car longer then that it hasexpired and needs to be renewed. | |
Friends: 0 | |
Friends: 1 | oops that's what i get for watching 2 tv channels and trying to read a post |
Friends: 4 | That's how it has worked in other sat radios I've had, plus I received a letter from XM saying it expires on the 11th and it is now the 7th as I write this. Does anyone know if there is actually an AM2? And I pulled the jumper pin to 'reset' the radio,but the presets are still set. I was trying to avoid losing the mileage info but since I already lost that I'm thinking of disconnecting the battery ground and see if that helps. Any other suggestions? |
| Junior Member Join Date: Sep 2009 Location: Gilbert, AZ
My Car: 2010 Prius Model: II Package: Base Thanks: 4
Friends: 0 | I believe it is one AM and Sat 1, 2 and 3. I bought my Prius thru a broker so I never got the trial period, but I do get the promo channel. Above info confirmed by the manual, page 296. Quote:
| Thanked by: | Sphyrna (10-07-2009) |
| Junior Member Join Date: Sep 2009 Location: San Jose CA
My Car: 2010 Prius Model: IV Package: Navigation Thanks: 1
Friends: 0 | |
| Umbra Tenet Join Date: Jul 2009 Location: Southern California
My Car: 2010 Prius Model: II Package: Base Thanks: 3
Friends: 0 | Just for the sake of completeness I'll point out that if you never had Sat radio installed you only get AM1. |
Friends: 4 | Well I called the dealer and they had never heard of this happening to anyone, so they asked me to bring it in. I guess that's what warranties are for, so I'm taking it in tomorrow. I'll post whatever updates after that. EDIT: The dealer concluded the radio was to blame and has ordered a replacement under warranty. We'll see next week if that takes care of it. Last edited by Sphyrna; 10-16-2009 at 10:07 PM. |
| am1, amsat, button |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-audio-electronics/70162-am-sat-button-only-gets-am1.html | ||||
| AM-SAT button only gets AM1 - PriusChat Forums | This thread | Refback | 11-13-2009 03:01 AM | |
| When do you use the EV button? | Bear68 | Gen II Prius Technical Discussion | 37 | 01-01-2010 02:50 PM |
| Help with EV button!!! | PriusLuver | Gen II Prius Main Forum | 3 | 11-05-2006 11:28 AM |
| button next to SKS on/off button | betshsu | Gen II Prius Main Forum | 18 | 09-10-2006 12:07 PM |
| E.V. Button? | mr.whit | Gen II Prius Main Forum | 0 | 04-30-2006 10:43 AM |
| Ev button | Raenstoirm | Gen II Prius Audio and Electronics | 2 | 04-20-2004 12:45 AM |
