This is a discussion on iPhone Users: Let's Band Together! within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; I've learned from others here that the reason the iPhone doesn't work as well as it could with the Prius ...
Old 10-11-2009, 11:45 AM   #1
bighouse
bighouse's Avatar
Default iPhone Users: Let's Band Together!
I've learned from others here that the reason the iPhone doesn't work as well as it could with the Prius is that the iPhone is using technology that's outdated. Apple needs to update the iPhone to support greater functionality and control of the iPhone from the Prius's Nav/Audio system. That can only happen, it seems, if Apple updates the "Audio/Video Remote Control Profile (AVRCP)" from the current version 1.0 to the later 1.3 or 1.4 which could allow for much more control of the iPhone from your steering wheel or Nav system. To send your request/comment to Apple, please visit:
Apple - iPhone - Feedback
To learn more about the AVRCP visit:
Bluetooth profile - Wikipedia, the free encyclopedia
Thanks- and make sure you pass this along to other iPhone users you know whether they own a Prius or not!!!
bighouse is offline
Old 10-11-2009, 12:57 PM   #2
Ads_green
Default Re: iPhone Users: Let's Band Together!
Hmm - not sure about that. I have several other bluetooth enabled cars and they all work fine with the iPhone including since the last update full voice dialing.
I think it's more the prius doesn't duplicate the sending the button hold properly.
Ads_green is offline
Old 10-11-2009, 01:47 PM   #3
rrolff
Prius Surgeon
rrolff's Avatar
AVRCP works over direct connect. AVRCP also works over Bluetooth - however, there is a software *bug* that prevents forward or reverse track over Bluetooth. This is a well documented bug, and will get fixed eventually - in fact it may already be fixed on the new OS 3.12 release.
If you ever intend to Jailbreak your iPhone, use it on a different carrier, run other non "Apple approved" apps, then doing the latest updates will permanently "lock" your iPhone...
rrolff is offline
Old 10-11-2009, 05:20 PM   #4
rstark18
rstark18's Avatar
In your other Bluetooth enabled cars are you seeing Track Information, Skip Forward/Reverse, Random, Repeat? If you are not seeing those buttons then you are not seeing an AVRCP 1.3/1.4 connection. The 2010 Prius (Nav Package) does support AVRCP 1.3 (see page 173 of the Navigation Manual).
AVRCP is a Bluetooth profile and is not used for direct connection (wired). AVRCP 1.0 in the 2010 Prius does indeed work as intended (with the iPhone 3.1.2 update) but that profile does not allow for any features beyond Play and Pause.
The point of this post is to pressure Apple to adopt a newer AVRCP profile. AVRCP 1.0 was adopted in 2003 whereas 1.3 was adopted in 2007 and 1.4 in 2008. Which bug are you referring to? The only bug I'm aware of was the one that would start the track from the beginning after the Bluetooth connection was stopped. This was fixed by Apple with 3.1.2.
PLEASE send your feedback to Apple requesting AVRCP 1.3/1.4.
rstark18 is offline
Old 10-11-2009, 05:32 PM   #5
rstark18
rstark18's Avatar
For those that want a quick and easy way to leave feedback, copy and paste the following to the link from the first post.
I would like to put in a request that the AVRCP profile that you use for Bluetooth be updated to a new version. The version you are using right now is AVRCP 1.0. I would like to see either 1.3 or 1.4 implemented. The reason for this is to allow car interfaces to show the relevant command buttons on their navigation screens (Forward, Reverse, Track Information, etc.). This implementation would create a safer driving environment by allowing the users to control the iPhone interface without picking up and looking at the iPhone.
rstark18 is offline
Old 10-11-2009, 07:38 PM   #6
blueumbrella
Member of Prius Regeneration
blueumbrella's Avatar
I sent Apple feedback based on your recommendations. Thanks for looking into this.
blueumbrella is offline
Old 10-13-2009, 04:18 PM   #7
jafca09
jafca09's Avatar
Package: Navigation
This might not be the best place to post this, but until I can control my iPhone's iPod through the in-dash screen, I've been primarily relying on the USB interface. However, the iPod will stop playing after 2-3 minutes and an error message will appear on my screen. If I unplug it and plug it in again, it will start working again temporarily. Otherwise, to get music to play consistently, I have to go through Bluetooth. Any ideas?
jafca09 is offline
band, iphone, users
Upcoming NAV for iPhone users... Cool stuff! Indyking Gen III 2010 Prius Main Forum 4 07-03-2009 12:44 AM
GREAT news for iPhone 3GS Users! swich2mac Gen III 2010 Prius Main Forum 14 07-02-2009 01:26 PM
iPhone: Do you think Apple iPhone Bluetooth will be Prius Compatible? osXcode Gen II Prius Audio and Electronics 21 06-30-2007 09:18 AM
Windshield Shade Band Tideland Prius Gen II Prius Modifications 10 08-14-2005 03:21 PM
Band movie rick57 Fred's House of Pancakes 9 05-09-2005 11:30 AM
