| This is a discussion on Dynamat the Doors........any suggestions? within the Gen III 2010 Prius Audio and Electronics forums, part of the Gen III (2010+) Toyota Prius Forums category; Here's a nice link to an alternative. costs less, but comes in every thickness (so you can mix and match). ... |
| | #11 |
My Car: 2010 Prius Model: N/A Package: N/A Thanks: 36
Friends: 0 | Here's a nice link to an alternative. costs less, but comes in every thickness (so you can mix and match).Soundproofing & Noise Control Materiels Prices |
| | #12 | |
| Junior Member Join Date: Oct 2009 Location: Midwest
My Car: 2010 Prius Model: V Package: Navigation Thanks: 1
| | #13 |
| Senior Member Join Date: Aug 2009 Location: El Monte, CA USA
My Car: 2010 Prius Model: II Package: No Package Thanks: 41
Friends: 0 | I used b-quiet extreme on my Gen III. I did all the doors, the entire floor and back seat, and the trunk. I chose the b-quiet extreme due to its weight of .30lb per sq. ft.. Keep in mind that sound deadening material such as hush matt and dynomat is to reduce vibrations and the Soundproofing material suggested by rrolff is to control sound. Soundproofing should be applied on top of sound deadening material. When I get the time, I will be finishing off the rest of the 35 sq. ft I have on the roof of my gen III. The prius is now quiet enough to be compared to my NAH.
__________________ --- 2010 Prius II Blizzard Pearl/Dark Gray : 8KWh Enginer Kit with 2 240V DC/DC converters 2008 Altima Hybrid Winter Frost/Charcoal Leather |
| | #14 | |
| | #15 |
Friends: 0 | I have seen others dynmat the back of the door panel but I did not. I guess you could to help stop the rattling but it does very little to ward off noise. I applied to the bare metal of back of the outer panel and the metal you see when you take the door panel off. |
| | #16 |
Friends: 0 | Thank you for all of the suggestions everyone. I decided to go with B-quiet Extreme 50 sq/ft roll. This is going way above and beyond what I originally intended, but if I'm taking the doors apart I might as well go all out and take steps to improve speaker sound quality, and reduce outside noise slightly. |
| doorsany, dynamat, suggestions |
| Dynamat | RBW111 | Gen II Prius Main Forum | 47 | 11-04-2008 03:41 PM |
| Cost for professional shop to install Dynamat in four doors? | John Milo | Gen II Prius Audio and Electronics | 4 | 04-22-2008 01:48 AM |
| Dynamat Question - Should I do the rear doors too? | andrewsilver | Gen II Prius Audio and Electronics | 10 | 03-09-2008 04:42 PM |
| DYNAMAT! | nikkiusaf | Gen II Prius Audio and Electronics | 12 | 01-22-2008 08:45 PM |
| Adding Dynamat | BethlehemPrius | Gen II Prius Modifications | 3 | 07-19-2007 06:15 PM |
