This is a discussion on any progress on the DIY oil change guide for 2010? within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Looks like I will be the first to do an oil change on our 2010 Prius III with Navi. I ...
Old 07-01-2009, 03:31 PM   #21
alfon
Package: Navigation
Default Re: any progress on the DIY oil change guide for 2010?
I have over 4,600 miles and the indicator comes on when the car is started stating maintaince reminder.
I will be using Mobil 1 (0 X 20) synthetic motor oil. The filter will be genuine Toyota. I will put in 3.5 quarts at first and see were that is on the dip stick. Currently it is about 1/4 inch below the high mark.
Book states from low mark to high is I believe 1.7 quarts. Max capacity is 4.4 quarts (U.S)
I have a filter wrench that should work and my plastic ramps will clear the front end.
I am just a litte worried about the bolts I need to take off to gain access to the engine oil drain plug and filter., hope I can find them.
Alfon
alfon is offline
Old 07-01-2009, 05:33 PM   #22
tumbleweed
tumbleweed's Avatar
Model: V
Package: Adv. Technology
Alfon
I don't think they are bolts Alfon, take a look at Wayne's pictures. Just three push pins, no tools need.
Anxious to hear how it works out for you.
tumbleweed is offline
Old 07-01-2009, 10:44 PM   #23
alfon
Package: Navigation
So, I am not a great mechanic but I have done my own oil changes on my 2003 VW TDI. There the lower engine cover to access the drain plug has screws, I believe 12 of them.
Now, with a push pin, you just push on the pin and the cover releases, and to install just place the cover back and push in on the pin?
Alfon
alfon is offline
Old 07-02-2009, 12:37 AM   #24
tumbleweed
tumbleweed's Avatar
Model: V
Alfon
Click on the top picture in post 12 and take a look. I think they come out of the holes completely. I'm not sure if they are the kind you just push on or if you need to pull the little button down and remove them. I don't have a car yet or I would go look. Anyway I think once you get under there and see them it will become obvious.
Old 07-02-2009, 12:59 PM   #25
alfon
Package: Navigation
Thanks for your help. I am looking at changing the oil this weekend by than our car will be at or over the 5,000 mile mark. The hard part will be trying to get the car away from my wife.
Also, no problems with the car. I noticed the gas mileage is improving a little. The last fill up netted 54.6 actual; guage displayed 57.0. But I believe the attendant did not stop the pump after the initail click and probably pumped in an extra tenth or two of gas.
This is based on reg gas with 10% ethanol.
In Oregon you can not pump your own gas.
Alfon
alfon is offline
Old 07-02-2009, 03:44 PM   #26
stream
stream's Avatar
Model: V
Package: Navigation
Alfon
I assume it's the same as when I replaced the front turn signal & fog light bulbs. There was a panel on each side that's secured by a philips head screw, and a plastic pin fastener. You use a flat head screwdriver to pull out the center of the connector, which disengages it. To reinstall you insert the fastener in the hole, and push the center "pin" in, which reengages it.
stream is offline
Old 07-02-2009, 08:54 PM   #27
alfon
Package: Navigation
Well, it will probably be easy than I think once I get under and take a look at the cover.
Thanks guys
Alfon
alfon is offline
Old 07-02-2009, 09:10 PM   #28
Bwalls
My Car: 2010 Prius On Order
Originally Posted by FireEngineer View Post
Here's a start, someone else can finish if they want.
From the rear
Attachment 16144
Wayne
What kind of wrench is used to remove the filter?
Bwalls is offline
Old 07-03-2009, 04:40 PM   #29
FireEngineer
Something like this one
Amazon.com: Toyota Oil Filter Wrench - TOY640, by Assenmacher Specialty Tools - Assenmacher Specialty Tools - TOY640: Everything ElseAmazon.com: Toyota Oil Filter Wrench - TOY640, by Assenmacher Specialty Tools - Assenmacher Specialty Tools - TOY640: Everything Else
is best.
Wayne
FireEngineer is offline
The Following User Says Thank You to FireEngineer For This Useful Post:
Bwalls (07-04-2009)
2010, change, diy, guide, oil, progress
2010 prius oil change alfon Gen II Prius Care, Maintenance and Troubleshooting 8 08-31-2009 06:25 PM
Four Year Progress Report TonyPSchaefer Gen II Prius Main Forum 13 08-27-2008 11:36 AM
GM shows off Volt, progress toward 2010 launch cwerdna Prius and Hybrid News 16 04-05-2008 04:26 PM
Is there a TCH users guide similar to john1701a's excellent prius guide? zsnark Newbie Forum 1 04-01-2008 09:33 PM
Healthy lifestyle progress marjflowers Fred's House of Pancakes 42 12-06-2006 12:44 PM
