This is a discussion on Batteries within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; 2001-2003 had batteries of substantially different design. They went through an early life special service campaign to re-seal the cells ...
Batteries
LinkBack (1) Thread Tools
Old 08-14-2009, 09:05 PM   #11
tochatihu
tochatihu's Avatar
My Car: 2001 Prius
Package: Pioneer #1
Friends: 14
Default Re: Batteries
2001-2003 had batteries of substantially different design. They went through an early life special service campaign to re-seal the cells to prevent electrolyte leakage.
Even so the failure rate of that design has been about 10% so far. Could be higher, our guesses are based on public postings. It is fair to presume that this rate will continue to climb, at least slowly.
Since 2004 the new battery design has been much more reliable. Even though the 2004+ fleet is much larger, we are simply not hearing of many HV battery failures.
I guess there are two origins for the battery fail 'myth'. One dates from about 2000 and is basically 'oh that can't possibly work' - unsupported by any data. Second is a (more or less accurate) assessment of the 2001-2003 design, but assuming that the same will apply to the new design. Unsupported by data.
DAS
tochatihu is offline
batteries
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-care-maintenance-troubleshooting/67137-batteries.html
2010 Prius | Addictomatic This thread Refback 08-13-2009 02:36 AM
Batteries for key FOB djasonw Gen II Prius Main Forum 2 06-02-2009 03:05 AM
Batteries grasshopper Gen II Prius Main Forum 17 01-21-2006 02:46 PM
batteries jo Gen II Prius Main Forum 2 05-10-2005 08:13 AM
Batteries DieselConvert Gen II Prius Main Forum 0 04-26-2005 01:39 PM
Batteries ian Gen II Prius Main Forum 7 11-08-2004 02:03 PM
