This is a discussion on Gen III oil filter wrench within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Originally Posted by patsparks . . . . from W Thanks, I owe you a frothy....
Old 09-10-2009, 07:51 AM   #11
Mark57
Mark57's Avatar
Model: II
Default Re: Gen III oil filter wrench
Originally Posted by patsparks View Post
. . . . from W
Mark57 is offline
Old 09-10-2009, 08:58 AM   #12
a64pilot
Originally Posted by kaptmorgan View Post
How much is the toyota Part?
My dealer maintains that he is not allowed to sell Toyota tools to the public, They would like to, but Toyota strictly forbids them.
a64pilot is offline
Old 09-10-2009, 02:47 PM   #13
jaywolf
jaywolf's Avatar
Originally Posted by windstrings View Post
This is the one I ended up buying.. .looks like made of good stuff and cheap.
I got this one
Toyota Oil Filter Wrench (09228-06501) 64mm/14 flute:eBay Motors (item 370247376286 end time Sep-17-09 18:15:34 PDT)
It looks about the same it has s 3/8 drive in the center so you don't need any socket just a ratchet.
jaywolf is offline
Old 09-10-2009, 03:38 PM   #14
mgb4tim
Noob
mgb4tim's Avatar
Package: Navigation
Originally Posted by Mark57 View Post
Unobtanium needs to be added to the PriusChat list of official terms.
It's part of both of the MG and Triumph forums I visit.
mgb4tim is offline
Old 09-10-2009, 06:00 PM   #15
windstrings
Certified Prius Breeder
windstrings's Avatar
Originally Posted by tumbleweed View Post
I think you did better than I did. I paid twice that much including shipping. Then I found out it takes a 24mm socket so I had to spend $7 more for one of those. The ebay one looks like it takes a smaller socket.
Ill wait till I get it to see..... Im betting I already have the socket.
windstrings is offline
Old 09-11-2009, 08:00 AM   #16
esoniat
Model: II
Default Do you really need a wrench? Re: Gen III oil filter wrench
I have seldom used a wrench, even on my ES300 where the filter was difficult to reach by hand. Has anyone removed this filter cartridge by hand? I'm pretty strong and it looks like there is really good access to get you hands on this thing.
I just don't want another oil filter wrench I never use lying around.
esoniat is offline
Old 09-11-2009, 08:52 AM   #17
windstrings
Default Re: Do you really need a wrench? Re: Gen III oil filter wrench
I would just go get a cheap one from Walmart.... these things are funny.. sometimes they break free and other times they are tough... IMO.. I'd rather want to know the job is going to be consistently easy and know what to expect... if you ever "can't" get it off, you will be forced to go to the store in the middle of the job or revert to banging on it with something and risk damage too.... its not worth the hassle to not have one IMO....
I've never done Cartridge, but it looks like it could be tougher than the regular type to get off.. but I could be wrong.
Alan
________________________
2010 Blue Ribbon Metallic IV with Bisque leather...."My Blue Baby"
And my "other" cars......
2006 Barcelona Red Prius Pkg #8 with Bisque leather.... Yea Baby, Yea! "The Hot Tamale"
2006 Silver Pine Mica Pkg#8 with Bisque leather.... "The Mint Julip"
2006 Mods so far:
1. Coastal EV switch 2. BT stiffening Plate 3.Zaino "the works" 4. Heat Shield "from Canvas Works" 5. Magnetic Oil plugs - Yes they work and you want them! 6. Speed sensor now switched!
Old 09-11-2009, 10:51 AM   #18
a64pilot
It is, your not, it's the drag of the O ring I believe that makes it harder. On a spin on the sealing gasket or O ring just meets up flush with a flat sealing surface, with a cannister, I believe the O ring goes inside of the engine so to speak, so your squeezing the O ring between the engine opening and the outside of the cannister. Hard to explain, but there was a lot more drag on the cannister on removal. I had to use the strap wrench to turn it several turns before it got loose, usually a spin on is loose in a half a turn or so. YMMV
a64pilot is offline
Old 09-11-2009, 11:04 AM   #19
windstrings
That makes perfect sense to me... the surfaces that move when you turn the canister have more contact area than a simple compression of both sides like with the Cannister type.
The threads themselves are probably no worse at all, its all about the O ring.
Old 09-12-2009, 11:58 AM   #20
Smoketrail
Smoketrail's Avatar
Model: II
I have used the KD #3253 65 mm end cap oil filter wrench on my 2010 Prius and found it worked great. I had to pry mine off with a screwdriver since it fit the oil housing so well.
Gen III oil filter wrench-smoketrail-albums-2010-prius-oil-change-picture2644-kd-3253-65-mm-end-cap-oil-filter-wrench-oil-.jpg
Smoketrail is offline
filter, gen, iii, oil, wrench
Oil Filter Wrench calabrsn Gen II Prius Care, Maintenance and Troubleshooting 16 05-03-2009 11:39 AM
Sweet oil filter wrench edthefox5 Gen II Prius Care, Maintenance and Troubleshooting 1 02-14-2008 05:44 PM
Correct Size OIL FILTER CAP WRENCH for 2007 ?? FloridaWen Gen II Prius Care, Maintenance and Troubleshooting 26 08-23-2007 04:22 PM
A tip: buy the Toyota oil filter wrench brick Gen II Prius Care, Maintenance and Troubleshooting 33 05-15-2007 04:42 PM
Oil Filter Wrench thusband Gen II Prius Care, Maintenance and Troubleshooting 9 06-19-2005 07:27 PM
