This is a discussion on Anyone using the Maintenance Log in the Nav Unit? within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; There's a fairly extensive record page under Setup => Vehicle => Maintenance for oil changes, tires, filters, etc. I've discovered ...
Old 09-20-2009, 11:58 PM   #1
Dark_matter_doesn't
Dark_matter_doesn't's Avatar
Default Anyone using the Maintenance Log in the Nav Unit?
There's a fairly extensive record page under Setup => Vehicle => Maintenance for oil changes, tires, filters, etc. I've discovered that it won't take data entries prior to today's date - I wanted to enter the oil change done a few weeks ago. I'm still working thru just how it works.
Is anyone using this feature, and what do you think of it?
Dark_matter_doesn't is offline
Old 09-21-2009, 04:22 PM   #2
lawboy
lawboy's Avatar
Package: Navigation
Default Re: Anyone using the Maintenance Log in the Nav Unit?
I used it to enter all of the maintenance checks for 5000 miles, but I'm not there yet. I intended to enter all of the required checks, but there is so much to enter, I decided to just enter what I need for each interval, then re-enter as I go along based on the manual,
lawboy is online now
Old 09-21-2009, 07:47 PM   #3
P3III
Gen 1 and Gen 3 owner
P3III's Avatar
Package: Navigation
It would be much more effective if Toyota would automatically load the intervals for you and the dealer would reset them when the service was performed. Too much data entry!
P3III is offline
log, maintenance, nav, unit
Portable GPS Unit Tomel51 Gen II Prius Audio and Electronics 4 06-12-2009 02:27 AM
Replacing the head unit on '06 with double din aftermarket unit azzieo Gen II Prius Audio and Electronics 8 01-15-2009 10:37 AM
For All that have the HD DICE unit seayayfishing Gen II Prius Audio and Electronics 5 06-29-2007 01:20 PM
New Sirius Unit? AlphaTeam Gen II Prius Audio and Electronics 0 10-10-2006 01:30 PM
New Sirius unit? AlphaTeam Gen II Prius Audio and Electronics 4 06-21-2006 12:50 PM
