| This is a discussion on Washing/Rinsing Help Please? within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; The water at my house is so hard that if you allow any drops to evaporate you'll have a white ... |
| Senior Member Join Date: Sep 2009 Location: Guerneville, CA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 5
Friends: 2 | The water at my house is so hard that if you allow any drops to evaporate you'll have a white spot where the drop used to be. So, just rinsing a car leaves spots all over the paint, chrome, glass, etc. My solar roof will be rendered useless in no time! So, I'm wondering if anyone has ever used Reverse Osmosis water in a small pump garden type sprayer (like for treating plants with insecticide) to do a final rinse before drying? Granted, if one drys the bad water off, I suppose you could get it all off before any of it evaporates, but on a warm day that's not very likely. I would love to NOT have waterspots on my Prius that I am going to pick up from the dealership in a few hours! And, two more washing questions.. 1. I've looked at all the chain autostores for Zaino and Garoits products- no one carries them. Are they available online only or are there big box stores that carry them? 2. My house doesnt' have a concrete driveway, it's gravel/dirt...so it makes washing my car unfun- mud/dirt/gravel sticking to my shoes, etc...has anyone ever invented any kind of a roll-out mesh matt to allow cars to drive atop of for washing them to keep the car washer himself clean??? I'm thinking like a 12' x 20' fiberglass type shadecloth tarp that one might drive atop. |
| I study nuclear science... Join Date: Apr 2008 Location: San Diego
My Car: 2006 Prius Model: N/A Package: #3 Thanks: 1
I can't speak intelligently about any specific products, but I've always experienced similar issues with water spots in San Diego. I have the best luck by washing the car in early morning when the sun is low and the humidity is higher due to the coastal marine layer (the water drops will not dry quickly). Any spots that do appear are readily taken out with the use of a microfiber towel. About using a fabric or mesh under your car, I would think that the weight of the car and the rocks/gravel below would quickly result in holes and tears in the material. After a few washes, your material would be toast. If a paved driveway is out of the question, you may want to consider installing pavers that are permeable with large openings for the grass to grow. It's a do-it-yourself project much cheaper than pavement, environmentally friendly, and solves your mud problem.
__________________ Mods: Two scangauges, body side moldings, mudguards, rear bumper protector, grill blocking. Coming soon: EV button, engine block heater Last edited by carz89; 09-24-2009 at 10:13 AM. | |
| Junior Member Join Date: Aug 2004
Friends: 0 | I use the "MR. Clean Car Wash System" available at Wal-Mart and other stores for about $25.00. With a soft nylon brush on a 4 foot handle it takes about 20 minutes. The sprayer, which goes on the end of the hose, contains soap for washing and a special cartridge that is used for a final rinse that eliminates all water spots. You do NOT need to dry the car to remove water droplets. Just let it air dry. You must use the Mr. Clean car wash soap and change the cartridge when it change color. Wash about 1/4 of the car at a time. 1. Spray on water to wet the surface. 2. Select the soap position and spary on soap. Use sparingly very little is needed. 3. Scrub area with the brush. 4. Rinse with clear regular water. 5. When entire car has been washed select the special rinse water and spray the car. The water comes out in a fan like spray. Use it as though you were spray painting the car. Again, use sparingly. One pass over the surface is enough. I have been using it for about two years. |
Friends: 0 | I assume you have an RO unit? Yes RO water will do what you want, so will a Mr Clean car wash thing Air hoses and leaf blowers will help a lot too.My Father while he was alive did home hemodialysis, that's where I am familiar with RO water. |
Friends: 0 | On the mat, go to a RV store. They have a plastic fake grass mat that's made to put under the awning of an RV. Ought to work perfect for what you want, folds up for easy storage too |
| Senior Member Join Date: Dec 2004 Location: Gaithersburg, MD
My Car: 2004 Prius Model: Package: #9 Thanks: 6
Friends: 1 | You might want to try using the ONR hoseless wash process that I wrote a thread about in here, its still on page 1 of the forum. My water is pretty hard too...and sometimes in the summer I will just do that to avoid the spotting... |
| Blizzard Pearl for Me Join Date: Mar 2009 Location: Triad, NC
My Car: 2010 Prius Model: IV Package: No Package Thanks: 78
Also, you could try rinsing your car in such a way that it would leave very little water on the car... See this older thread here: Keeping the Prius shiny... | |
| Bio-Medical Equip. Tech Join Date: Jul 2009 Location: St Louis, Mo
My Car: 2010 Prius Model: II Package: Base Thanks: 2
Friends: 0 | A better idea than reverse osmosis would be to use a water softener. Install one in the house. It will protect your hot water heater from calcium build up, all of your plumbing and keep the sinks and shower free from build up also. Your wife will thank you because she will have an easier job cleaning. They are easy to install (~2hrs). You also need an outlet for the timer. It doe not add salt to the water but replaces the calcium ions with sodium ions so the water will not tast salty or leave salt spots on the car. $300-$500 depending on the capacity Last edited by JRitt; 09-24-2009 at 05:44 PM. |
| formerly known as "Popoff" Join Date: Nov 2006 Location: NC Mountains
My Car: 2010 Prius Model: V Package: Navigation Thanks: 33
Friends: 1 | Quote:
www.zainostore.com www.griotsgarage.com | |
Friends: 2 | Quote: Then clay bar it with the Zaino claybar product. After that though I'm a bit confused as Zaino seems to make all kinds of different polishes to top it off after that cleaning....Do I then use the Z-AIO product and then finish it with the Z-2 with occasional use of Z-6??? Someone please just tell me what to do?!? I have the dark grey leather interior, so I went ahead and ordered the Griot's Ultimate Interior Care package- seemed like it would have all the cleaners and conditioners I might need for the interior (except maybe carpet care). But, I'd like to see what you really experienced with Zaino would recommend as the "ideal exterior package" of products for my little red beautiful car. | |
| washing or rinsing |
| Rinsing of the car set off an alert | PriusRos | Gen III 2010 Prius Main Forum | 10 | 08-29-2009 10:01 PM |
| Car Washing | lstendig | Gen II Prius Main Forum | 30 | 04-15-2009 08:32 PM |
| Washing the key fob | stevendwatson | Gen II Prius Main Forum | 5 | 11-28-2008 11:02 AM |
| Washing the car too much? | SparrowHawk60 | Gen II Prius Main Forum | 24 | 05-25-2008 10:54 AM |
| Car Washing 101 | tofupriusgirl | Gen II Prius Main Forum | 12 | 10-12-2007 07:37 PM |
