This is a discussion on Tip for DIY oil changes within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Last summer I had prostate surgery, I say this so you won't think I'm completely crazy and if you do ...
Old 10-02-2009, 03:57 PM   #1
Vaughn
Model: V
Package: Adv. Technology
Default Tip for DIY oil changes
Last summer I had prostate surgery, I say this so you won't think I'm completely crazy and if you do I hope you would at least give me a free pass. I purchased 24 absorbent pads that measure approx 30X30 inches, these have one side plastic and the other has the absorbent material. These were purchased for my home recovery and I only used a few. Found a use for them, place them with the drain pan on top and spread it so I have the area is fully covered. If I miss the pad something bad must have happened. When oil change is complete if pad looks OK I fold it and use it again, if not I wrap any rags, etc and dispose of it. You can get them in any medical supply store or online.
Vaughn is offline
Old 10-02-2009, 04:07 PM   #2
Mark57
Mark57's Avatar
Model: II
Default Re: Tip for DIY oil changes
Interesting and creating use of materials on hand.
I also just got an urge to go drink a quart of cranberry juice.
Mark57 is offline
Old 10-02-2009, 06:01 PM   #3
Vaughn
Model: V
Mark,
I'll take that as a free pass.
Vaughn is offline
Old 10-02-2009, 08:32 PM   #4
a64pilot
You'll laugh but when the kids were in diapers I used to use one to catch the oil spills from removing the oil filter in a Miata. A Miata even way back in 1990 has a plastic pan under the engine like a Prius, but without the neat door.
I think those blue pads are called chucks or something similar? You can even buy pads for boats that won't absorb water, but will absorb oil.
a64pilot is offline
diy, oil, tip
