| This is a discussion on I'm going inZaino today.... within the Gen III 2010 Prius Care, Maintenance and Troubleshooting forums, part of the Gen III (2010+) Toyota Prius Forums category; Later in the day after the sun has lowered far enough in the western sky behind my house and trees ... |
#1 |
| Senior Member Join Date: Sep 2009 Location: Guerneville, CA
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 3
Friends: 2 | Later in the day after the sun has lowered far enough in the western sky behind my house and trees I'm going to wash and prepare my car for the Zaino treatment many here have recommended. My kit from Zaino contains: ClayBars Z-2 Pro New Z-5 Pro Z-6 Ultra Clean Gloss Enhancer Z-7 Show Car Wash Z-fx Special Effects Accelerator Show Car Polish I have my Dawn ready too. So, after I wash with Dawn, and then use the claybar with some Z7 diluted for lubricant, do you rinse the car again or do you simply dry wipe off any residue from the claybarring before proceeding to the next step? And just what is the next step??? 2010 Barcellona Red IV... |
| Member Join Date: Sep 2009 Location: AZ
My Car: Other Hybrid Model: N/A Package: N/A Thanks: 0
Friends: 0 | After you clay each panel I would just wipe it off with a quality microfiber towel. Regarding the Zaino steps, I am not sure how they work. I know Zaino recommends Dawn but I think as long as you have a quality car wash detergent, you will be fine. If using Dawn, make sure you use enough to make it very sudzy, and rinse it well before you clay. Below is a link from Autopia (detailing forum) where a member outlined the steps. Hope it helps. Zaino manual - Autopia.org |
Friends: 2 | OK, sounds like I do this: 1. Wash car with Dawn, say 2-3 oz in a gallon of water with sheepskin mitt from Griot's. 2. Rinse thoroughly but complete drying isn't essential- though I likely will so as to remove any possible waterspotting (hard water)...may even spray with RO water from a garden sparyer after initial rinse to give it a final rinse so any standing water droplets won't be as likely to leave hardwater spots. 3. Mix a bit of Z7 car wash into a spray bottle and kneed the claybar and go at it, spraying the surface/bar along the way. Cover all painted surfaces..(Does this include glass surfaces or the solar roof?) Microfiber wipe away residue as I go. Feel for smoothness... 4. Mix 2 oz of Z2 or Z5 (Barcellona Red paint- is one preferred to the other???) along with 4-5 drops of accellerator into vial and shake it up for a while..then apply a dime size onto the Zaino cotton applicator. Work the mixture into the paint in straight line movements. Cover all areas of the car's painted surface. Allow to dry to a haze then remove with a microfiber cloth. 5. Repeat application of mixture as in step 4 again- no need to wait between coats due to the accellerator... Does this sound about right? |
| A Fairly Senior Member Join Date: Jun 2006 Location: Rockville, MD
My Car: 2010 Prius Model: IV Package: Solar Roof Thanks: 201
Friends: 2 | Use Dawn for the first time you wash it before applying Zaino. Dawn will strip any wax that might have been applied to the car before and allow the Zaino to bond better with the car's finish. You won't use Dawn for subsequent washes. After claybarring, I'd suggest rinsing it down again. Then you have to make sure the car is completely dry before starting with the polishes. I'm not sure what to advise about using Z-2 versus Z-5 first, or whether you really need both. But, whichever one you use, mix it with the Z-FX accelerant (follow directions carefully). The Z-FX lets it dry much faster, otherwise you have to wait hours between coats. After you've applied one or two layers of the Z-2 and/or Z-5, finish up with the Z-6. This is the easiest step. You spray on and wipe it until dry, so you don't have to wait for it to dry. It gets rid of any polish residue you might have missed and enhances the gloss. By the way, start early -- don't wait until it's too late because you might not be able to complete everything before dark. Unlike wax, Zaino actually likes the heat. Putting it on in the sun won't cause it to bake on and get too hard to remove.
__________________ 2010 Prius IV with solar package Winter Grey with Misty Grey interior and dark grey floormats Took Delivery 7/31/2009 Previous car: 2006 Prius Package III, Classic Silver Metallic |
| Push the Button! Join Date: Feb 2007 Location: San Diego
My Car: 2007 Prius Model: N/A Package: #6 Touring Thanks: 3
Friends: 1 | |
| Member Join Date: Aug 2009 Location: Orange County, CA
As for applying, I think you apply as you would with normal wax, in circles, first (to ensure coverage), and then finish with straight line movements (back and forth-horizontal surface and up and down-vertical surface). As PriusRos said, you might want to start early. Even with the Accelerator, it does take a good deal of time to wash, clay, apply and remove. Hope you have fun! Post pictures when you are done. | |
Friends: 59 | I was going to ask you to wait because winter is coming but you are in CA, so ... nm. |
Friends: 2 | OK...I lied the other day about going all Zaino that day...just didn't have the time...but today I washed with Dawn...Claybar'd with Z8 wash dilute...Washed with Z8...and then when all dried, put on a coat of Z5 with the FX admixture...then another coat after that one was removed...and now I'm waiting for the final coat of F2 to dry and I'll remove it. Oh, I also put on my front mudflaps...may tackle the rears tonight too. It was basically an all-day process for me. |
| Junior Member Join Date: Sep 2009 Location: Tempe, AZ
My Car: 2010 Prius Model: V Package: Navigation Thanks: 1
Friends: 0 | Where and how did you get mud flaps for the 2010? Also, what did they cost? I'm interested in getting them for my V. Thanks! |
| Member Join Date: Jul 2009 Location: twin cities
My Car: 2010 Prius Model: II Package: No Package Thanks: 6
| inzaino, today |
LinkBack to this Thread: http://priuschat.com/forums/gen-iii-2010-prius-care-maintenance-troubleshooting/70005-im-going-inzaino-today.html | ||||
| Gen III 2010 Prius Care, Maintenance and Troubleshooting - PriusChat Forums | This thread | Refback | 11-08-2009 10:00 PM | |
| Got One Today!!!!! | Flying White Dutchman | Newbie Forum | 6 | 01-28-2008 08:46 PM |
| I Got It Today..... | rayben | Gen II Prius Main Forum | 3 | 08-28-2006 05:49 AM |
| Ran Out of Gas Today | K5VMI | Gen II Prius Main Forum | 5 | 03-03-2006 01:41 PM |
| No car today | Raenstoirm | Gen II Prius Main Forum | 10 | 04-23-2004 10:13 PM |
